Old 03-22-2006, 10:45 AM
gest24's Avatar
$ gest24 $ gest24 is offline
#1 6MT In Cali
Radiator Drain
Thought I'd drain and re-fill my rad today. How do you go about doing this?
Sand Diego SCCA Solo 2 #308
RIP
84 VW Scirocco
02 WRX
Check My New Homepage..
Old 03-22-2006, 10:58 AM
It's preferable to remove the underbody tray first then set a container inther the passenger side of the radiator where the drain "spigot" is. Just unscrew and let the coolant flow.
Best to leave the cap on until it's flowing. Removing the cap will increase the flow.
After filling run the engine with the cap off and add coolant until it takes no more. Don't forget about the overflow tank.
Old 03-22-2006, 12:03 PM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
I've also found it helps to elevate the front end about 8". For some reason it seams to aid the removal of air from the cooling system faster.
1994 LSi (4/93)
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
