engine problems
OK here we go again. Now my engine has decided it's going to blow out a rod bearing now that I have 4.44's. I'm working on that problem right now with svxfiles and I can hopefully get it solved before Reading.
The problem I want to solve right now is I changed my oil and cleaned my throttle bodies, Ans also found a ground wire disconnected on the back of the motor from the dog bone mount on the tranny to the firewall that I hooked back up. Now my idle will not drop below say 950 RPM with the lights on and warmed up. It idled at 600-650 before I did the work. I checked my vacuum lines on the intake and they are all hooked up. What else could it be?? |
maybe you clogged up the AIC which is located on the bottom of the TB. Try to drive it for a while and see if it will clear up
Tom |
Thread Tools | |
Display Modes | |
