Old 03-19-2006, 01:16 PM
Antigenus's Avatar
Antigenus Antigenus is offline
Send a message via AIM to Antigenus
Brakes
My new brake setup (caliphers, brake pads, and front rotors) are squeeling like crazy sometime when I slow down or use them, especially at low speed to stopping. The ABS light is on also, Im sure this ties together. Anyways, I just put these on and it sounds like straight metal on metal grinding sometimes, and everything is still there....any ideas?
Matt - Akron, OH
And then what???
Old 03-19-2006, 02:17 PM
Are the pistons on the calipers sticking and not giving even pressure?
Old 03-20-2006, 06:31 AM
kuritsa kuritsa is offline
Sorry if this sounds obvious but did you install the pads with the friction material facing the disc. It's a simple mistake to make.
Old 03-20-2006, 06:42 AM
Antigenus's Avatar
Exclamation
yea, the brakes are on properly, but the piston issue sounds more realistic. Sometimes after I brake coming up to a stop it feels like the brakes are still slightly "pinching" the rotor and it takes a little motion forward until the brakes feel like they full disengage. Is the piston pressure adjustable or is did I not install it properly? They just make sooooo much noise something cannot be right.
Matt - Akron, OH
And then what???
