Old 03-14-2006, 08:44 PM
empera empera is offline
Help. Need picture/diagram of Starter!!
hey guys im pretty much a n00b with this because i just got the car and havent really worked on it much. I think i installed the starter wrong and im really stunned with some explanations.
I need a simple picture of the Starter installed onto the car ASAP Please!!
Old 03-14-2006, 10:38 PM
Speedklix's Avatar
Locker Link Solution
see attachment...
B is where you attach the POS wire which has the big rubber boot that covers it and the nut afterwards. S is where the little signal wire slips on. and the ground wire attaches to a bracket that the starter mounting bolt slips through.
Hope that helps
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 03-15-2006, 05:47 AM
thanks a lot bro...that helped a lot.
Old 03-15-2006, 11:58 AM
did u figure it out??
