Old 02-24-2006, 09:44 PM
Ricochet's Avatar
Ricochet Ricochet is offline
I brought some ham.
so I did the alternator mod..
and my lights are still flickering. Headlights, dome light, spot lights, gauge cluster lights, everything.. Happens at all rpms, throttle positions, and while stopped.
Brian
Old 02-25-2006, 06:41 AM
zavikan zavikan is offline
Hmmm
I'm thinking something probobly went wrong along the way. (Just helping out )
'92 Liquid Silver SVX - Drilled&Slotted Rotors/Canadian OEM Seat Warmers/JDM Folding Mirrors/JDM Clear Corners/Euro Glass Headlights/Euro Headlight Level Adjustment/Euro Shifter Assembly/ECUTune Chip V.1/GARAGE QUEEN!
Old 02-25-2006, 09:53 AM
Mabe a bad ground? That is what I would usually think, but if you did the additional ground, that should not be. Interesting.
Old 02-25-2006, 11:53 AM
Ricochet's Avatar
I brought some ham.
I did everything correctly, I've been working with electronics for 5 years now.. I went pos to pos, neg to neg to chassis.
Brian
Old 02-25-2006, 12:32 PM
I meant a bad connection as in poor or not a good one. Not saying that your skills are bad, but with 12 volt systems, ground is one of the things that always is hard to find and will do wierd stuff.
Old 02-25-2006, 01:37 PM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
It sounds like the voltage regulator is pooping. I've had more than one alternator do this when dying. Good luck.
Old 02-25-2006, 01:56 PM
Ricochet's Avatar
I brought some ham.
how hard would it be or how much does it cost to replace?
Brian
Old 02-25-2006, 02:10 PM
Budfreak's Avatar
Banned
I believe it's on the inside of the alternator(internal regulator). I'm not 100% familiar with the alternator, But you more than likely may as well replace the whole alternator. Have you taken any voltage readings?
Old 02-25-2006, 03:04 PM
Ricochet's Avatar
I brought some ham.
yeah 14v at idle with the radio on.. these cars are funny.
Brian
Old 02-25-2006, 03:21 PM
Budfreak's Avatar
Banned
Yeah, I know. Is it a steady 14V? No fluctuations? Do the lights flicker in a steady pattern or is it random?
Old 02-25-2006, 03:45 PM
Mine was doing this too. I took it to the shop and they took it off the car and sent it to an alternator shop to test. Turns out the alternator was going bad (all they told me was that there were "serious internal problems"). They replaced it and now it is fine, no ficker at all in the lights. It even seems like it fixed my rough idle.
Old 02-25-2006, 09:03 PM
Ricochet's Avatar
I brought some ham.
Hmmm. Guess mine is probably going out then.. budfreak, I drove it to the auto store and they checked it for free. It sat at 14 for quite a bit, like 20 seconds.. and yeah they flicker at a steady beat.
Brian
Old 02-25-2006, 11:01 PM
Budfreak's Avatar
Banned
If it's flickering at a steady beat then that points towards the voltage regulator or possibly a dead spot on the windings inside the alternator. Chances are the flicker is so quick that a digital voltmeter isn't quick enough to see it. Try a computer friendly analog meter. Was the auto stores meter digital or analog? Let me know. -Jason
Old 02-26-2006, 01:39 AM
Crusader's Avatar
Crusader Crusader is offline
$13000 and counting...
Send a message via AIM to Crusader Send a message via MSN to Crusader Send a message via Yahoo to Crusader
Same thing happens to me on an alternator that was replaced less than 2 months ago... Haven't tried the wiring mod yet, but if I do that and no luck I'm taking it back to NAPA to get another Alt.
Old 02-26-2006, 02:32 PM
Ricochet's Avatar
I brought some ham.
Theirs was digital.. it was on some big cart that he had to push outside.
Brian
