Old 02-12-2006, 04:46 PM
tangwichjustin
Identifying 5 speed transmission
Hey all I was wondering how I can identify the transmission I just bought. It's supposed to be from a manual 5 speed wrx. The only two things I can find on it is FM-5 stamped on one side and FM-3 stamped on the other side. In addition there is a number 587465 on a sticker near the bell housing. I need to find out so I can get the correct wiring harnesses for it, and any other things it may be missing. Thanks a ton everybody.
Old 02-12-2006, 08:00 PM
mbtoloczko's Avatar
sans SVX
Have a look here:
http://www.rallispec.com/Transmission%20chart.htm
Mychailo
Visit my locker
Old 02-12-2006, 08:10 PM
92svx95 92svx95 is offline
hey
hey justin this is paul, read your pm
Old 02-12-2006, 09:10 PM
tangwichjustin
Sent you a pm back Paul. If you don't see it does the number I'm finding on the tranny of 587465 somehow crossreference to the wrx tranny number you got of TY754VN2AA?
Old 02-13-2006, 04:32 PM
does the clutch slave cylinder point toward the front or the rear of the trans??
Old 02-20-2006, 09:28 PM
tangwichjustin
Hey Tom I checked out the tranny and the clutch slave cylinder points toward the rear of the vehicle, that tell you anything important about it?
Old 02-20-2006, 11:46 PM
tells me its not a WRX transmission
