Old 02-09-2006, 11:39 AM
Amazonparrot's Avatar
Amazonparrot Amazonparrot is offline
Now with Colder Air!
Send a message via AIM to Amazonparrot Send a message via MSN to Amazonparrot
Undying Blinking
My power light blinks at startup 16 times. I have been informed that this means a tranny code is present? Is this still applicable and true for me, i have a 20ohm resistor and the smallcar shift kit. Thanks! (trying to get my car in tip-top)
1992 Subaru SVX LS-L Ebony Mica: Custom Cold Air Intake, Smallcar Shift Kit, ECUtune Stage 1v4, Flowmaster Exhaust, UR underdrive pulley, 4.11 gears, iRotors Drilled and Slotted rotors, Axxis Brake Pads, 18" Enkei Wheels w/Pirelli Pzero Nero M+S, 20% Window Tinting, K&N Panel Filter, Rockford Fosgate Sound System w/XM Radio, Removed Intake Resonator *SOLD*
2003 Subaru WRX: 2003 Impreza WRX (Aspen White); Vishnu Stage II; IHI VF-34 Turbo; Walbro fuel pump, STi Injectors, Vishnu Up-pipe, Down-pipe and Signature 3" Cat-back; Samco Intercooler hoses; JIC Coilovers; STi A-arms; Whiteline swarbar bushings; Stoptech 13" rotors w/4-piston calipers; Braided Steel brake lines; 17" Rota Wheels with 225/45/17 Falken Azenis (R-Comp).
Charlottesville, VA Represent! (voted #1 place in America to live!)
http://www.subaru-svx.net/photos/user.php?Amazonparrot
Old 02-09-2006, 12:15 PM
Check the tranny (TCU) code with the instructions in the SVXipedia on http://svx-iw.com/
If you're getting code 11 then you have too much combined resistance (resistor + shift kit)
Old 02-09-2006, 05:01 PM
DarknessofDeath's Avatar
Inhabitant of Darkness
that explains somethings...kind of (in my case)
thanks
