Old 01-21-2006, 09:16 PM
Ricochet's Avatar
Ricochet Ricochet is offline
I brought some ham.
What's involved in a 90k mile service?
Just got a letter with a 10% coupon off a 90,000 mile assraping service, and I want to do whatever I can by myself.
Brian
Old 01-21-2006, 09:35 PM
n00b on demand's Avatar
Probably a bunch of fluid changes and tire rotation.
Old 01-21-2006, 09:57 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
The 90K service is equivalent to the 30K service. Don't have my owner's manual infront of me, but I would assume it would be the replacement of all fluids (trans, front & rear diffs), filters (air & fuel filters) and a tire rotation like Tom mentioned. It's probably a $300+ service, which you can do yourself in the Spring for ~$50.
2006 Steel Gray WRX TR (sold)
Old 01-21-2006, 10:25 PM
I bet you will never guess what I found in the How-To Documents. Look here to find out.
Old 01-21-2006, 11:37 PM
Ricochet's Avatar
I brought some ham.
A chart listing things to inspect and replace up to 60,000 miles? wow thanks!
Anyways.. I've changed all fluids and plugs since buying her 5 months ago (4,000 miles since then), and all the belts look brand new. Tires look great, everything drives fine.. what about a valve adjustment? Is that super expensive?
Brian
Old 01-21-2006, 11:40 PM
Chiketkd's Avatar
Nice find Earl!
Ricochet, 30K service = 90K service as I mentioned above... (likewise 120K service = 60K service)
-Chike
Old 01-22-2006, 12:11 AM
mbtoloczko's Avatar
sans SVX
Originally Posted by Ricochet
.... what about a valve adjustment? Is that super expensive?
The hydraulic lifters automatically hold the lash at ~0. So, the lash never needs manual adjustment.
Mychailo
Visit my locker
Old 01-22-2006, 01:14 AM
Ricochet's Avatar
I brought some ham.
Good, one less thing..
Brian
Old 01-22-2006, 08:46 AM
SlonSVX5mt
TIMING BELT! Most important i would think.
Old 01-22-2006, 09:39 AM
Thats done at 60K and 120K...if it hasnt been done yet at 90 then do it along with the water pump and thermostat.
Old 01-22-2006, 11:24 AM
Originally Posted by Chiketkd
Nice find Earl!
-Chike
It is amazing what you can find behind that handy little button that says How-To Documents.
