Old 12-13-2005, 03:12 PM
Boxer6SVX's Avatar
Boxer6SVX Boxer6SVX is offline
Dont Drink and Drift
awd bias on svx's
I was told that the SVX is a 70F/30R awd setup... In looking at all 5 of the examples that subaru uses I cannot place our cars into any one category.. So since Ive been driving my car fwd I have only been using 70% of the available power? Or can the AWD sense that only the front wheels are pulling and send 100%?
1995 850Ci
1988 Prelude~ B20 swap
2006 Mustang GT (RIP)
Old 12-13-2005, 03:16 PM
#1 why are you in FWD mode??
#2 The power split vaires dependant on wheel spin and engine load
There is no real way to tell what % it is at unless you monitor it with a Select monitor.
Overall you are right though, the SVX auto has a FWD bias
Old 12-13-2005, 03:27 PM
n00b on demand's Avatar
Some have reported it is 90/10...some have said its 60/40....let me find chike's thread on it from a while ago.
Boxer6SVX's Avatar
I am having to deal with a busted rear dif so I removed the rear half of the driveshaft to make it essentially fwd until I get the rear diff replaced (this week)
And friday my front dif went... so now im NOwd
Was just curious if it has been sending me 100% between the front tires since the rear is disconnected.
1995 850Ci
Old 12-13-2005, 03:29 PM
http://www.subaru-svx.net/forum/show...ight=awd+chike
You're using 100% of the engine's output all the time. It's only a ratio from front to back.
Boxer6SVX's Avatar
Chike rocks... Im so glad hes just an hour away :-D
Gonna need a knowledgeable guy to walk me through this rear dif install
1995 850Ci
Old 12-13-2005, 07:20 PM
JD da ricer
Lightbulb
I have a fuse plug-in for FWD mode. Ive put a 10amp fuse in it and ran the car in FWD for a day, which was really fun because I was doing burnouts at stoplights without even trying. Does putting the car in FWD hurt the transmission or affect the wheel horsepower?
Old 12-13-2005, 07:35 PM
Boxer6SVX's Avatar
If it can handle a 90/10 bias then Im sure it can... but beware.. I put 2000 miles on mine fwd and now I have a "bowl of steel cereal" for a front differential.
1995 850Ci
Old 12-13-2005, 09:51 PM
The front diff can handle 100% but it is the transfer clutch you are hurting more by doing burnouts like that. Your front diff was on it's way like so many before it that using 100% FWD probobly hastened it's demise
Old 12-13-2005, 10:01 PM
Boxer6SVX's Avatar
Me personally... tires are to expensive and Im not as stupid as I was in my teens.. I take care of my things now... Cant say Ive personally done anything stupid in this car. It took me too long to find one as it is to just ruin it.
1995 850Ci
Old 12-13-2005, 10:46 PM
JD da ricer
yea, i looked at my front tires today and the treads looked more worn down than the tread on the rear. I'll refrain from burnouts from now on. I'm gonna try FWD at the dragstrip and see how it affects my time.
Old 12-14-2005, 02:21 PM
Boxer6SVX's Avatar
Other than traction I dont think its going to affect your times much.. Whether its FWD or AWD youre still using 100% just in a different bias.
1995 850Ci
