Old 12-10-2005, 06:54 PM
1320boy's Avatar
1320boy 1320boy is offline
Team ROUND 1
Send a message via Yahoo to 1320boy
Power Window Problem
Im wondering if there is a fuse or something else wrong with my passanger power window.
I dont want to have to replace the motor for it so is there something that i can do or check???
Im very And its only my passanger all the others work.
Can someone help me?
Old 12-11-2005, 06:48 AM
immortal_suby's Avatar
Thread Killah
Could be a number of things.
Do you hear a motor turning when you try to open the window or do you hear nothing?
You will have to remove the inner doorskin to get a look at it before we can help any.
Locker Link
2015 BRZ Limited 6MT
Old 12-11-2005, 11:53 PM
1320boy's Avatar
Team ROUND 1
But im wondering if there is a fuse that i can check before i start ripping things apart????
Old 12-12-2005, 12:08 PM
billb billb is offline
Does the passenger window work from the driver's switch? How about the rear windows? I thought my rear windows were working, but they were only working from the driver's switch. Do they work from the driver's switch and from their own switches? Make sure.
If your problem is that the passenger's window does not work at all from any switch, then the fuses should be OK. You'll have to start tearing into the door to find the problem.
Bill
94 SVX LE 130,000mi
Old 12-12-2005, 08:30 PM
1320boy's Avatar
Team ROUND 1
son of a *****
i was hoping that i wouldnt have to tear **** out.
but i want to make sure, where is the fuse just incase. all the other windows work just not the pass front
Old 12-12-2005, 08:32 PM
1320boy's Avatar
Team ROUND 1
son of a *****
i was hoping that i wouldnt have to tear stuff out.
Old 12-12-2005, 08:58 PM
kuoh kuoh is offline
Actually, the door panel is pretty easy to take off. Just pray you don't have to replace the rear speakers, now those are a pain to get to.
KuoH
Old 12-13-2005, 05:23 AM
I agree that the door panel is easy to get off. I was afraid of breaking a bunch of clips but there was no problem. I'll have to look up where the fuse is tonight.
Bill
94 SVX LE 130,000mi
Old 12-13-2005, 12:46 PM
1320boy's Avatar
Team ROUND 1
Thanks man i really just want to check that before i think that i have to replace a motor when i really didnt have to
Old 12-13-2005, 01:13 PM
I'll look tonight. I'd still be optimistic that it's the switch and not the motor. The switch from the driver's control gets routed through the passenger's door switch.
Bill
94 SVX LE 130,000mi
Old 12-13-2005, 03:51 PM
There are two fuses in the power window circuit. Unfortunately, per the diagram, either fuse will kill all 4 windows. But, here is the info:
1) In the Main Fuse Box, Fuse is SBF-1. It's a 30 amp fuse near the middle of the fuse box.
2) In the fuse & relay box, it's fuse no. 15. It's a 10 amp fuse in a 7 by 3 array of fuses.
As I remembered, the power for the passenger's window is routed through the switch on the passenger's door. So, even when controlling the window from the driver's switches, the power goes through that passenger side switch. You'll have to pull the door panel to determine if the problem is in the switch or in the motor. That little switch on the passenger's door has 5 terminals and there's a few different modes of switching going on in that little guy. You'll just have to put a voltmeter on the wires to the motor and see if you ever get power to the motor when you use the driver's switch, or if you use the passenger's switch. If you're lucky, you won't ever have power to the motor and you can just replace the switch. I know the switch is about $40. I would guess that the motor is quite a bit more expensive.
Again, pulling the door panel is easy. Pull out the felt down in the door handle. There's a couple of screws down there. There's another screw under the door latch release lever. There's a very easily accessible screw right through the panel over toward the hinge area. After removing those, use a big screwdriver to pop out all of the plastic pins. Then push the panel straight up toward the window opening. That's it. Just be careful with the wiring that will be hanging back there.
Good luck.
Bill
94 SVX LE 130,000mi
Old 01-08-2006, 12:57 AM
1320boy's Avatar
Team ROUND 1
ok i tried and did all that i even pulled the motor out and it works there's power going to it what else could it be????
Old 01-08-2006, 08:56 AM
Thread Killah
Could be the cable has snapped or the sleeve lock regulator has broken. Do you see a cable going up and down when you have the door skin off?
Locker Link
Old 01-08-2006, 11:41 AM
odepaj's Avatar
odepaj odepaj is offline
Killer of threads
I have a problem similar to this, none of my windows work, or my sunroof, the power drivers seat works though. When I try to roll down the window I can hear a buzzing sound from inside the door panel, the same happens when I try to open the sunroof, I can hear a buzzing coming from inside the headliner? I think it only does this with the drivers window and the sunroof, none of the other windows make the buzzing noise but they dont roll down either? Any thoughts? Thanks
dustin
-Dustin
Old 01-08-2006, 05:45 PM
1320boy's Avatar
Team ROUND 1
Yeah yeah. but i hear a clicking sound
nothing "LOOKS" out of place, but then again i didnt build the car niether.
