Old 12-01-2005, 07:00 AM
alia176 alia176 is offline
Front suspension bushing replacement
I'm on a conquest to reduce/eliminate front end clunking. After seeing how the front sway bar bushings were totally swelled up and destroyed from the oil leaks up front, I'd like to replace other suspension bushings up front. So far, I've found:
- (4) 20136PA000 Stabilizer Bush
I can't seem to get a p/n of the bushings that are inside the front control arms. Shouldn't these be replaced as well? I'm also wondering if I should replace the rubber stabilizers on top and bottom of the strut springs.
(2) 20325PA000 Rubber Stabilizer Up
(2) 20325PA100 Rubber Stabilizer Lw
Thanks for any help.
Ali
'92
'92 SVX LSL
'03 4Runner
'96 FZJ80 Landcruiser
'90 Mercedes 300E
Old 12-01-2005, 11:19 AM
Anyone?
'92 SVX LSL
'03 4Runner
'90 Mercedes 300E
Old 12-01-2005, 02:36 PM
SVX_MY_BABY's Avatar
Earthworm is doing a group buy on bushings. Check that thread.
If you are trying to get rid of the klunk. Good luck. the SVX is known for it. Subaru even re designed the struts to help solve it ( to the detriment of handling in my opinion). They replaced them in the 92's under warranty for those who wanted them changed.
Old 12-01-2005, 02:57 PM
I was never able to find a source for the Control Arm bushings, Subaru call them "Non-Servicable" and only sells the whole CA, complete with bushings.
I replaced mine with good control arms off of a parts car.
Old 12-01-2005, 05:08 PM
mbtoloczko's Avatar
sans SVX
What Hocrest said.
Mychailo
Visit my locker
Old 12-01-2005, 05:20 PM
Good info, thanks. I'll check out the Group buy on bushings.
It's really cold today and I'm noticing more clunking from the front I'll check my BJ too just in case.
Ali
'92 SVX LSL
'03 4Runner
'90 Mercedes 300E
Old 12-02-2005, 09:42 AM
PaulSVX's Avatar
PaulSVX PaulSVX is offline
There is a SB for that particular problem
1992 Pearl White SVX LS-L
1991 "Red Baron" Grand Prix GTP 5spd
2002 Chevy TrailBlazer LT
Old 12-03-2005, 04:36 AM
Any place where I can go to look at this SB? Links/PDFs/etc?
Thanks.
'92 SVX LSL
'03 4Runner
'90 Mercedes 300E
Old 12-05-2005, 10:13 AM
All the TSB's for the SVX are in the SVXipedia on http://svx-iw.com/
