Old 08-23-2005, 06:46 AM
halistan's Avatar
halistan halistan is offline
Grand Poo-Bah
Send a message via AIM to halistan Send a message via MSN to halistan Send a message via Yahoo to halistan
I have 235K miles on mine and in the last 5 years (since i've gotten it) I know its had this done:
Transmission replaced with a 97 model tranny
Tranny cooler
2 timing belts
2 water pumps
valve cover seals
cam seals
crank pulley (old one split apart)
new rotors
steel braided brake lines
ECU crush mod (not really a replacement but i listed it anyway)
new front struts
new spark plugs (about to be done again)
custom exhaust w/new cats
replaced antenna
4 sets of tires
& two radios
Those are all the things i replaced my self. When i totalled it (right after i bought it, here is what i had done..it had about 115K miles on it then)
New bront body parts (hood, fenders & bumper)
radiator
new ABS system
new condensor
new evaporator
new headlights (and middle grill piece)
front turn signals
frame straightened (13 hours on a frame machine)
'93 LS-L named "Samantha Victoria Xavier"...Sam for short.
All new and improved custom built engine with forged internals, lowered compression, upgraded cams and a stage III supercharger. AMR Engineering struts, Custom exhaust --All 3 Subaru cats removed, and replaced with 2 high flow mustang cats-- Cross-drilled & Slotted rotors, steel braided brake lines, bypassed stock Tranny cooler replaced with aftermarket B&M super-cooler, and a K&N drop in air filter.
Old 08-23-2005, 01:39 PM
EddieSVX's Avatar
EddieSVX EddieSVX is offline
shiftin' an automatic
Send a message via AIM to EddieSVX
92 LS-L. Currently 85500 miles.
- Tranny rebuilt, front axles replaced, powersteering pump seal fixed, and driver side power window switch/window rubber stopper replaced, all at around 75000 miles.
- Original front rotors warped, replaced all 4 corners with aftermarket at around 84000 miles.
- Oil disptick 'o' ring worn, making the dipstick popout randomly (that sounds perverted). Put new 'o' ring at around 85000 miles.
That's about it for "major issues". Okay, so most weren't really major.
By the way, the tranny wasn't slipping before the rebuild, it was just having issues going into reverse and sometimes it would "flare" during shifts. The gears, etc, were in great shape when they opened her up for the rebuild. The 4EAT is actually a very strong transmission, it just tends to run hotter than most and its casing design isn't optimal for heat decipation. This can lead to premature wear and/or failure of internal components. I thought I'd mention this because dispite having to be rebuilt, I was amazed about how great of shape the items that matter were.
Eddie
'92 SVX LS-L (For Sale! Info and link to pics... ) #9536 blt. 4/92 (late boomer '92)
'01 Audi S4 (2.7L Twin Turbo - 6MT)
