Old 08-20-2005, 08:42 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Originally Posted by Hocrest
Sorry Chike, but I think Melis bested your time for the NA Modified 4EAT. 14.708 @ 91.77 in the racer.
Dave,
Is the racer back in AWD mode? I thought it was still running in FWD mode?
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 08-20-2005, 10:05 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
In all fairness, there should be another class for stripped down racers...
I wonder how fast my car would go if it weighed 2,800lbs!
-Chike
2006 Steel Gray WRX TR (sold)
Old 08-22-2005, 05:40 AM
Originally Posted by SVXRide
Dave,
-Bill
Yeah, It's been AWD for a while now.
Old 08-22-2005, 07:42 AM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Yeah Bill, the dif was in when you drove it. She's pulling like a bat out of hell out of turns now. The launches are something of beauty to see. 2.5k rpm starts with narry a chirp.
Old 08-22-2005, 07:55 AM
SVXRide's Avatar
which means you obviously don't have enough gearing in it
-Bill
Old 08-22-2005, 08:00 AM
benebob's Avatar
-Bill
I can churp it big time coming out of a turn, on straight pavement though no. I was sitting 4th fastest overall time when I left on Sunday. Expect to be in the top 10 once results get posted. Not bad considering the course was tight as can be in spots and our tires are in the wiggly stage with the nubs just getting taken off on my first run.
Old 11-23-2018, 10:01 AM
sd2649's Avatar
sd2649 sd2649 is offline
Driving in Style
Re: Fastest SVX ever for 1/4 mile? Anyone know?
BUMP. Any other list like this? I keep seeing EG33's with huge power on the internet, but they're never in an SVX. :-(
-Steven
1992 SVX Purple and Black 5 speed swap
SOLD
*1993 SVX Silver and Black
*1994 SVX L Barcelona Red FWD
Old 12-22-2018, 10:49 AM
sd2649's Avatar
Driving in Style
Bueller...
-Steven
SOLD
Old 01-02-2019, 08:50 AM
sd2649's Avatar
Driving in Style
Still wondering.
-Steven
SOLD
Old 01-05-2019, 01:32 PM
svxnavyvet svxnavyvet is offline
Young Toms silver shadow got into the 12sec area I believe. It is getting a new 3.7 motor put in it with lots of other mods will be shooting for the 10 sec area
there is good reading in here about it do some search on shadow machine
Old 01-05-2019, 09:32 PM
shotgunslade's Avatar
Who has YT’s car now, and what are the plans for it?
Old 01-06-2019, 01:20 PM
I do and working on the 3.7 motor to go in it along with a lot of suspension work. going to run the 3.7 in another car till it gets broke in then put it in the shadow with the supercharger
Old 01-24-2019, 03:06 PM
halistan's Avatar
halistan halistan is offline
Grand Poo-Bah
Send a message via AIM to halistan Send a message via MSN to halistan Send a message via Yahoo to halistan
I bought the Supercharger kit that JAYSVX had in CA and put it onto Icingdeath's rebuilt engine. I installed a Hydra and its in the shop now getting a new exhaust and tuned. When its done, i'll let you know how it turns out.
The shop estimates it can squeeze out about 350-400HP from it with 12psi of boost. We're also looking at fabricating a new intake manifold to allow more air in. Rather than going up (due to the hood being in the way) they think they can spread the manifold out sideways to make more room for flow. We'll get to that after we get it running the way it is. If they can though, that will open the door for a lot more power. We'll see.
'93 LS-L named "Samantha Victoria Xavier"...Sam for short.
All new and improved custom built engine with forged internals, lowered compression, upgraded cams and a stage III supercharger. AMR Engineering struts, Custom exhaust --All 3 Subaru cats removed, and replaced with 2 high flow mustang cats-- Cross-drilled & Slotted rotors, steel braided brake lines, bypassed stock Tranny cooler replaced with aftermarket B&M super-cooler, and a K&N drop in air filter.
