Old 01-27-2005, 11:21 PM
Bxsvx Bxsvx is offline
How fast is fast?
Send a message via AIM to Bxsvx
Would a 93 or up rear knuckle work on a 92?
Just curious, but I know that the 92's are the ones that have the most problem with the rear bearings. How about changing them to a 93 or up? I know those have the least issues, to my knowledge so far.
Old 01-27-2005, 11:30 PM
mbtoloczko's Avatar
sans SVX
Yes, they are interchangeable.
Mychailo
Visit my locker
Old 01-28-2005, 07:56 AM
red95svx
Re: Would a 93 or up rear knuckle work on a 92?
The knuckles are the same, so I'm not sure that changing them is going to do anything unless your knuckles are damaged. You hear more about problems with the 92 models because there are more of those than all the other years combined.
