Old 10-03-2004, 04:38 PM
Wiz Wiz is offline
Send a message via ICQ to Wiz Send a message via AIM to Wiz Send a message via Yahoo to Wiz
A built up supercharged EG33. Can't think of anything sweeter.
Green 1994 SVX LSi - Totaled by a plow. RIP
Bordeaux Pearl 1994 SVX LSi - 182k
Old 10-03-2004, 05:48 PM
Quad 100lb pulse jets.
Old 10-03-2004, 06:33 PM
marlettpat marlettpat is offline
THE MEMBER
Send a message via AIM to marlettpat Send a message via Yahoo to marlettpat
all new body panels done in bullet-proof material!
Would love an SVX of my own...
Old 10-03-2004, 07:26 PM
Imprezzed's Avatar
Imprezzed Imprezzed is offline
Some Toolbox rolled it!
Send a message via Yahoo to Imprezzed
Photon Torpedoes.
1992 SVX LS-L Claret - RIP.
Old 10-03-2004, 07:29 PM
Tranny cooler and filter.
Old 10-03-2004, 08:44 PM
majeskyb's Avatar
majeskyb majeskyb is offline
What about the setup they did to the Viper in the show, "viper"? That would be C001
To boast about the show's technical "accuracy", there was an episode where the Viper's ecu was fried. The "nerdy one" said that one from another car would work- so they jacked one out of a honda!
2010 F-150 King Ranch
2004 GTO- cammed, intake, exhaust, tuned, 382whp
Old 10-03-2004, 09:41 PM
Matthewmongan's Avatar
Matthewmongan Matthewmongan is offline
no limitation as limitation
the levitation think that the delorian had in that movie. and cup holders
Old 10-03-2004, 09:43 PM
DUDE.
Temperature controlled cup holders.
Old 10-03-2004, 10:07 PM
Bizarre Bizarre is offline
Send a message via AIM to Bizarre Send a message via Yahoo to Bizarre Send a message via Skype™ to Bizarre
Infrared or thermal imaging and a radar jammer.
Not to be used near airports of course.
'95 SVX LSI Black, just wire mod.
New speakers + homemade front mounts.
"In times of peace, a gentleman keeps his sword at his side." Sun Tzu c 300 b.c.
Old 10-04-2004, 09:06 AM
Pure_Insanity8's Avatar
Pure_Insanity8 Pure_Insanity8 is offline
Send a message via ICQ to Pure_Insanity8 Send a message via AIM to Pure_Insanity8
How about the "flux capacitor?"
"Oh YEAH... well my SVX can travel through time!"
-Aaron
SVX: '92 Dark Teal 101k
'97 Legacy GT Wagon: dead
'99 Civic Si: daily driver... stolen and stripped with all my tools!
'92 Yamaha FZR 600: garage
2011 Jetta: Daily disappointment
Old 10-04-2004, 10:56 AM
mikecg's Avatar
mikecg mikecg is offline
I'd add.........
The winning Florida Lottery ticket to the glove box
Old 10-04-2004, 11:18 AM
Originally posted by NikFu S.
DUDE.
i have a popular science issue that tells you how to make one of thoes it plugs into you cig liter. ill try to dig it up
boom!
The Peltier-Powered Self-Cooling Coolie
Scott Fullam
Peltier junctions are amazing little devices that look like oversize Chiclets and use electric current and semiconductors to move heat to one side, leaving the other cold. They’re typically used to cool PCs in which the main processor has been overclocked to run faster (and, consequently, hotter) than the manufacturer intended—a popular hack among hardcore gamers.
I’m not really into the overclocking scene, but Peltiers fascinate me. I recently picked one up just to play with it and thought, What could I cool with this?
“Mmmm ... beer,” my inner Homer Simpson replied. So with some epoxy and a heat fan, I hacked together a quick prototype of a Peltier-cooled metal stein. It worked, but required a large 12-volt power supply that had to be plugged into the wall. That’s fine for geek parties, but I wanted something nominally more useful. Realizing that my car has a great 12-volt power source (the cigarette lighter outlet), I modified the design and ended up with a coolie that can keep a standard 12-ounce can (of soda, of course) at a perfect chill indefinitely.
Yes, I know you can buy in-car devices that can cool a whole six-pack or heat a bowl of ramen noodles—and that’s fine, if shopping is your thing. Me, I like to build. If you do too, here are the basic directions, and see “Mods” (below) for design alternatives.
THE PARTS LIST
One 12-volt Peltier junction* (also called a thermoelectric device): $25
Can coolie: $1
Cigarette lighter plug with five-amp fuse: $4
Two to three feet of two-conductor, insulated, 18-gauge wire: $5/spool
Small 12-volt CPU or GPU cooling fan and heat sink: $10
One square foot of aluminum foil: $1/roll
Tube of silver-based epoxy: $15
Heat-shrinkable tubing or electrical tape: $3
Nylon tie wraps: $2
Total: $66
*Peltier Junctions (also called thermoelectric devices) available at magaland.com. All other parts available at Radio Shack and your local grocery.
BUILDING THE COOLIE
(1) Wad the foil as tightly as possible into the base of a soda can.
(2) Temporarily connect the Peltier junction to your cigarette lighter plug (see Step 4 for connections) and power it up to figure out which side is cold and which is hot.
(3) Flatten the other side of the foil ball and attach it to the cool side of the Peltier with silver epoxy.
(4) Solder the wires on the cigarette lighter plug to the two-conductor wire to extend its length, and connect the other end to the Peltier junction: plus (+) wire to the Peltier’s red wire; minus (-) wire to the black Peltier wire.
(5) Use the silver epoxy to glue the fan?heat sink combo to the warm side of the Peltier device (with the fan blowing down). Wait for the epoxy to set, then connect the fan wires to the Peltier wires in parallel: red to red, black to black. Cover the exposed connections.
(6) Cut a hole in the bottom of the coolie just large enough to fit the foil ball. Push it in far enough to completely contact the bottom of a can placed in the holder. Cut two small holes near the bottom and connect the stack with tie wraps.
MODS:
Try cooling from the side instead of the bottom. Just shape the foil to fit the curve of the can and carve a hole in the side of the coolie to hold the cooling stack.
Try multiple Peltier junctions to increase the chilling ability. You’ll need a 10-amp fuse in the cigarette lighter plug, and make sure all your Peltiers together don’t draw more than about 100 watts.
Old 10-04-2004, 11:52 AM
NapaBavarian's Avatar
Good morning!
I've wanted to put those in a car for years, ear plugs mandatory
.Karl.
Old 10-04-2004, 04:56 PM
Brock94SVX
Cup holder is trival.. I drink coffee every morning. I have found ways around the cup holder.. and uhmm doesn't the center open up and have a set in cup holder placement (yeah i know ghetto) but hey still has one...actually two -lol-.
I'd have to say... and manual for sure and a moonroof (I have an L FWD didn't come with moonroof.)
Yeah I didn't know anything about SVX's until after i bought mine (shame shame) If only I known then what I know now..it'd at least been a LS AWD with a sunroof..but ideally I will own a barcalona red LSi one day...next to my baby blue. and damn gotta get some of those porsche rims i think.
Oh here's some triva?
What's the difference between a "SUNROOF" & a "MOONROOF?"
Old 10-04-2004, 05:03 PM
MaG18
sun rook slides all the way back, moon roof only pops open
