Old 09-19-2004, 09:30 AM
Tiamat-red's Avatar
Tiamat-red Tiamat-red is offline
Following the path of the beam
Studded vs Studdless tires?
Which would be better for my SVX?
215-55-16 Hankook w404 Studded
225-50-16 Blizzak ws-50 Studdless
Matt!
92 Ebony LS-L "Jabberwerwok" Now includes 1 *free "Wheeeeeee" per ride!
83 Honda Magna v45 "Grendel"
*Free after mail in rebate
Old 09-19-2004, 02:17 PM
TorG0d
i would definately go with studless tires to avoid unwanted strain on your drivetrain.
Old 09-19-2004, 03:08 PM
Tiamat-red's Avatar
Why would that cause extra strain?
Matt!
Old 09-19-2004, 03:19 PM
I would go studless. The ones with studs would tend to skate unless on ice.
Old 09-19-2004, 07:09 PM
Tiamat-red's Avatar
In that case, should I stay with 225 on my stock rims, or go 215?
Would 215 be ok for 7.5" rims?
Matt!
Old 09-20-2004, 07:28 AM
SVX_MY_BABY's Avatar
I use 215 55 16 studded Nokian Hakapalita I tires. They do not skate on dry pavement. Years ago studs did that. Today the technology has improved.
If you have slush, glare ice, black ice, freezing rain or just plain frozen slippery roads, safety tests prove that you can stop 30% better with studs. They also give you much better cornering traction on ice before you lose control.
Nokian has an "Ecco Stud" stytem which is superior to other types. Their "Haka" tires are rated as good as Blizzak and Michelin Alpine. (They are made in Finland)
Rule of thumb when buying any snow tire is to go narrower than your summer tire, not wider. Wide tires ride up over the snow then the weight of the car pushes them down, like a plough. Narrower tires cut through the snow better, parting it rather than pushing it.
This link may help.
http://www.nokiantires.com/newsite/index.html
This article is helpful if you are not interested in studs.
http://www.cbc.ca/consumers/market/f...res/index.html
Another link:
http://www.tc.gc.ca/roadsafety/topic...er/wintere.htm
