Old 09-14-2004, 08:37 PM
kmin
replacing body panel
would it be cheaper to have a body shop repair a dent in my rear left corner panel, or to buy a panel from a parted svx and just replace it? i'm not sure what exactly would be involved with either process. anyone have any info, tips, hints, suggestions? the dent is pretty substantial; judging from the height of it, i'm assuming a sport hostility vehicle swiped my car as it was pulling out from a parallel parking spot (and of course left no note to apologize, etc.).
kmin.
Old 09-14-2004, 10:40 PM
Mr. Pockets's Avatar
Moderator
The quarter panels are, just as in any other unibody car, welded in place. Replacing the entire panel would be very expensive. I've looked into it.
http://www.subaruparts.com/diag/?mod...category=520-A
There's the panel. So you have to remove everything around it, drill out every spot weld, put a new one in and paint it all.
That's the short version. It'd be a lot of labor.
I have little doubt it'd be cheaper to repair the dent than replace the entire panel. You can't just 'get one out of a parted SVX.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 09-15-2004, 08:41 AM
If the dent can be repaired then it will be cheaper...unless the panel needs to come off in which case you may as well put a new one on.
Get an estimate.
