Old 09-13-2004, 04:19 PM
CONSUME
help me put in 5spd
My tranny is toast. I won't bore you with another bad tranny story, but i have to say it was going when i bought it a year ago so...not bad. I'm going 5 spd. I just started shopping for parts.
question #1.
I found a 95 legacy manual transmission. Will it fit?
question #2.
should I buy the kit from smallcar?
Old 09-13-2004, 04:48 PM
Bxsvx Bxsvx is offline
How fast is fast?
Send a message via AIM to Bxsvx
You really dont need to buy the kit from small car, you can easily go to any junkyard and buy all the parts off of a impreza, legacy. I think that the 95 legacy should fit, but you should double check on that. I even read somewhere that wrx's trannies fit.
Old 09-13-2004, 06:21 PM
Subafreak's Avatar
Superbeast
Hay stranger. Any Legacy tranny will work, it's only a matter of weather you get a cable or hydralic system. The cable is a bit easier to install. You just have to make sure you get the right pedal assembly to go with it.
Old 09-14-2004, 10:51 AM
The smallcar $299 DIY kit will help a lot when it comes to fabricating some of the parts required for the conversion but you can get by without it (like I did). Good luck with the conversion!
Old 09-14-2004, 12:27 PM
The 95 Legacy tranny will be fine....Basically the same as what I put in mine...
Old 09-14-2004, 06:27 PM
simonton
i was all set to put in a 5spd but got screwed and couldnt come up with the money... this might help if you still havent made any purchases...
svx 5spd
Old 09-15-2004, 10:38 AM
CONSUME
hey subafreak. Thnx for the feedback. ya I'm going to look at the trany..they want 500. I haven't talked to them about all the parts I need aLSO BUT...I think I can get it all for the same. My friend is a fleet mech. so... he's really good at hydrolics so....I am prob. not going cable. What's with the small car 5th gear? Does anyone else have it? I like the highway cruise the car has now but...don't use it much here in long island.
Old 09-20-2004, 01:58 PM
CONSUME
does the drive shaft of the 95 legacy need extending?
Old 09-20-2004, 02:14 PM
If it's out of a manual Legacy, it will have to be shortened 1/2", this is cheaper than extending one, as they don't have to supply any more tube, just cut 1/2" out of the front section.
You also have to put the SVX carrier-bearing bracket onto the Legacy Driveshaft for it to mount to the floor correctly...
This just entails drilling out the spot-welds on the bracket, and re-welding it back onto the Legacy driveshaft.
Old 09-20-2004, 02:18 PM
mbtoloczko's Avatar
sans SVX
A '95-'99 Legacy manual drive shaft needs to be *shortened* by 3/4" in the front section.
Mychailo
Visit my locker
Old 09-21-2004, 11:07 AM
CONSUME
thnx...man you guys are great. Has anyone thought of investing in a carbon fiber shaft? Is it a significant reduction in weight?
Old 09-21-2004, 12:50 PM
CONSUME
What car has the fitting pedal essembly?
Old 09-21-2004, 01:07 PM
None....
There is no "Direct fitting peddal set" it takes a little bit of modification, using some of the parts from a manual pedal set on the SVX auto pedal box
Old 09-22-2004, 01:57 PM
I used a WRX pedal set w/SVX gas pedal. This is for a hydrolic clutch though but was almost a direct bolt in.
Old 09-28-2004, 11:54 AM
CONSUME
Ya I think that sounds good how complicated is the fabrication. I my budget is not that huge so... if i can get away with the savings of not buying the diy kit from small car, I would like to. If the fab is going to take forever then...I would rather save the day+ of labor..
I'm going hydrolic so that peddle asmb. is what I will go with.
Thnx for help.
