Old 08-27-2004, 10:09 PM
Shadow248 Shadow248 is offline
Rep from the outside world
Send a message via AIM to Shadow248
Originally posted by Subafreak
I may be be confused thoe. The ones I'm familier with are like the 92 to 94 Bird/Camaro and a 92 Vette. All of them had that piss poor front mounted dist. that leaks oil and rusts inside. What motor is that exactly? Now there is also a DOHC motor that came in the Vetts right? What motor is that?
Ok I will try to keep this fairly brief, because I could type forever on it.
LT1 (350ci OHV V8 with MPFI) - used in 1993-1997 "Camarobirds" and 1992-1996 Corvettes. Rated at 285hp in the Camarobird and 300hp in the Vette. This is the one that had the ridiculous "Optispark" distributor that just blew goats. It's also the scary one to work on. Everything is in the way of everything.
LT4 (350ci OHV V8 with MPFI) - used in 1994-1996 ZR1 and Grand Sport Corvettes. This was the LT1 on crack. Wicked cam and high flowing heads gave it 380hp, but still the ridiculous distributor and space problems.
LT5 (350ci DOHC V8 with SFI) - used in the 1992-1993 Corvette ZR1 only. One wicked mother. 405hp. This engine was even tougher to work on than the LT1 and LT4 and to top it off, parts were expensive too. Thus the reason it was ditched in favor of the SLIGHTLY better LT4.
LS1 (346ci OHV V8 with SFI) - used in 1997-2004 Corvette and 1998-2002 Camarobird. New all aluminum setup saved weight and improved heat dissipation, SFI system combined with Coil-On-Plug ignition took care of the plagues of the LT series. Also used dual cat exhaust system which cleared out the bottom of the engine bay and made it much easier to work on. Rated at 350hp for Vettes and 325hp for Camarobirds. Actually produced 345hp in all applications. This is where the "underrated" reputation came from.
LS6 (346ci OHV V8 with SFI) - used in 2001-2004 Corvette Z06 and 2002 GMMG ZL1. Again, wicked cam and high flowing heads made 405hp. Just as easy to work on as LS1.
So my car is the LS1 with a custom ground cam from LPE and other supporting bolt-ons that i'm told will give me 420hp at the crank. I'm told by many people that once I get this car tuned properly, I will actually see more around 450hp. So that's exciting. Now comes the problem of how the hell to get all the power to the ground. Money money money.
Originally posted by Chiketkd
Lingenfelter is a famous Corvette tuner, and since the two cars shared the same powertrain, mods for a C5 corvette could also be used on the F body cars (Trans Am's and Camaro's).
Affirmative. However these things are much easier to install on the vette because the vette's engine doesn't reside halfway underneath a HUGE dashboard. I'm beginning to hate that. The thing that really sets LPE apart from the rest is their attention to detail. So many other companies' products need trimming and milling to fit. ALL OF LPE's products fit and work perfectly the first time. They tend to cost a tad more though.
Originally posted by upnygimp
The only good place for a LS1 is under the hood of a FD3S RX7. Now there's a real sports car. None of this silly Camarobird nonsense.
I'd love to see an RX-7 with an LS1 under the hood. Now there's a REAL engine. None of this silly Mazda rotary nonsense.
Old 08-28-2004, 04:11 AM
upnygimp's Avatar
upnygimp upnygimp is offline
Unstoppable
I agree with you on that point. The 13B is a terribly unreliable engine.
http://www.hinsonsupercars.com/
Look around there.
2008 Mazdaspeed3 GT
1985 Toyota MR2 (10 yr project)
Think of how stupid the average person is, and realize half of them are stupider than that.
-George Carlin
Old 08-28-2004, 06:01 PM
Subafreak's Avatar
Superbeast
Wow that does brake it down well.
So LT, BAD
LS, GOOD
Thanks and have fun doing burnouts and donuts
Old 08-28-2004, 07:43 PM
thundering02's Avatar
Giong back to the beaters...
loosing truck LT laughing sportscar LS
89 240sx se Black~185k R.I.P.
85 Toyota pickup ~205k R.I.P.
