Old 10-22-2003, 03:54 PM
Porter
Exclamation INFO: How to format posts legibly using Quote tags and formatting options
Greetings all,
I'd like to offer a short, concise primer on the use of vBulletin formatting tags.
vBulletin script, or vBCode, is a markup language similar to HTTP, the Hypertext Transfer Protocol. It uses tags surrounded by brackets ( [] ) to indicate changes in text formatting.
A "tag" is a command that is placed on either side of a set of characters to be formatted. Tags work in the following way...
If I want to use the imaginary text formatting command "bright", and I want only the word "ship" in the following sentence to be bright, it would be typed in like this:
I saw the [bright]ship[/bright] sailing into the harbor.
Obviously "bright" is not a real command or using it would have changed the way the word "ship" appeared in the sentence once the post was submitted.
There are a number of tags in the system, some which are well documented and others that are not, such as the "marquee" tags and other annoying items.
Commonly used formatting tags are "b" for bold text, "i" for italic text, "size" to change text size, and "color" for the obvious.
Other tags can be used to separate sections of text. Examples of these are the "quote" tag, the "code" tag, and the "php" tag. These tags all place text in an indented area, but handle the content of the text differently. The "quote" tag indents the text but allows normal text formatting within the indented area. The "code" tag indents the text and disables HTML tags that are used within it, so that you can see the tag markup. The "php" tag takes that one step further, disabling vBCode tags, and color codes the markup tags (and any other type of script) into sections based on codification.
Here are some examples of text formatting tags in their native form, followed by the same text after going through the vBulletin post system:
PHP Code:
The [i]quick[/ibrown fox [b]jumped[/bover the lazy [u]dog[/u].
The quick brown fox jumped over the lazy dog.
If I had quoted that using quote tags, it would look like this:
You simply put the start tag [ quote ] without spaces in front of what you want quoted, and close the quoted text with [ /quote ], obviously again without the spaces.
I hope this helps, for further information please see the built-in vBCode help document located here. It gives you some good information with regard to web links, email addresses, and image posting. Hopefully the image posting will become useful in the near future if the gods of the SVX Network smile on us and bring us into the modern internet age.
Hope this helps!
-Porter
Old 10-22-2003, 04:06 PM
Darksied-X's Avatar
Darksied-X Darksied-X is offline
Recluse
Send a message via MSN to Darksied-X Send a message via Yahoo to Darksied-X
[bright]I'm not[/bright]
Hey...how come it didn't work?
-Evil Jeff
'03 WRX Wagon, World Rally Blue
'94 SVX LSi, Barcelona Red
'89 XT6 4WD, Grey & Rust
(and legally, an '01 Outback VDC skankmobile)
Old 10-22-2003, 04:33 PM
Thanks Porter,
Worth while and appreciated time and effort on your part.
Why don't we start a " How to post in the " within in the How To Documents. Your info should be kept and available and not be allowed to slide into the archives.
Old 10-22-2003, 04:38 PM
Porter
Thanks, Trevor!
[marquee]Some tags are more annoying than others... [/marquee]
Oops, looks like the marquee tag isn't enabled on this board. I'll do some looking and see what's there and what's not.
Old 10-22-2003, 04:42 PM
immortal_suby's Avatar
Thread Killah
Thumbs up
Alternatively you can use the buttons for bold, italic, underline, and quote which are directly above the box you type in when posting. This will pop up a box that you write in and it automatically inserts the tags. Works well for lazy people me
Locker Link
2015 BRZ Limited 6MT
Old 10-23-2003, 06:26 PM
Porter left out the most important command i.e. You gotta hit the vB code Enahanced Mode button ! Howsat Have a play you can preview and delete your test posts.
Old 10-24-2003, 06:57 AM
Porter
Yep! Teh Intarweb is cool. Makes meh feel liek a h@x0r!
