Old 09-15-2003, 02:55 PM
The Molinator
Question Front Bearing R & R
Please point me to the remove/install instructions for FRONT BEARINGS (OEM). [I'll be using a HubTamer] Do I need to remove tierod end ball joints? Thanks!
Jim
Old 09-15-2003, 03:19 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Unbolting the lower ball joint will be required to allow axle removal. Separating the tie rod end will make the job soooo much easier.
Old 09-15-2003, 03:20 PM
lee lee is offline
don't know if there is/isn't a front bearing how to....but
Beav is the originator of a trick that has you remove the three bolts at the bottom of the lower A-arm. This allows the hub to be pulled out enough to get the axle out without disturbing the ball joint and eliminates the need for a realignment. A diligent search will turn up a bunch on axle removal - then it's just a matter of knowing how to use the hub tamer.
basically,
remove wheel,
remove axle nut,
remove 3 bolts,
remove pin on transmission end of axle,
remove axle,
use hub tamer to R&R bearing,
reverse,
live happily ever after - or until you need the car again,
(whichever comes first)
