Old 09-18-2003, 09:03 AM
rufus's Avatar
rufus rufus is offline
I look like Gordon
Re: Re: NEW STRUTS - Which Kind?
Originally posted by mbtoloczko
Your only options are OEM or Koni. There is no KYB option. Fortunately, the OEM or Koni options appear to be about all that's needed. The Koni option consists simply of a strut damper that must be put in place of the stock damper on an OEM strut body. It requires cutting, welding, fitting. You can do it yourself, or pretty soon, you will be able to buy an already converted OEM/Koni strut from Porter. Either way, be ready for sticker shock. The Koni option is a minimum of about 2x more expensive than OEM, and that's if you do all the conversion work yourself.
Just to clarify, there is no welding involved in the installation of the strut insert. And the Koni inserts are about $600ish for the set, OEMs are around $400 if I'm not mistaken.
-Mike
First the smiles, then the lies. Last comes gunfire.
Old 09-18-2003, 10:05 AM
mbtoloczko's Avatar
sans SVX
Re: Re: Re: NEW STRUTS - Which Kind?
-Mike
oops. Sorry about the mis-info. I saw a picture of Porter doing some sort of welding on a strut body and assumed it involved the Koni inserts. If you buy online, OEMs are around $375. I thought that the Koni inserts were around $640. Not quite 2x I guess, but then there are the costs to install the Koni inserts into the stock strut bodies.
Mychailo
Visit my locker
Old 09-18-2003, 09:04 PM
The Molinator
Question KONI'S
Tell me more about the Koni's and where to get them, please?
THANKS!
Jim
Old 09-18-2003, 11:32 PM
mbtoloczko's Avatar
sans SVX
Re: KONI'S
THANKS!
http://www.classicgarage.com/
or
Talk to Porter. He's putting together a ready-made high performance spring/Koni combo. His setup sounds very good to me if you are going to go with Konis.
Mychailo
Visit my locker
Old 09-21-2003, 03:48 PM
The Molinator
Question Custom Spring/Koni combo?
Is Porter using the custom spring I heard about on another thread which you arranged to be fabricated for a few network members for $375. a set? I assume their $640. per set price for SVX Koni's does not include the springs ("high performance spring/Koni combo") you mentioned on my thread.
Let me know, Please. I'm ready today to do my front bearings (I hear a familiar noise - hope it's the fronts, did the rears recently), but can't decide whether to do struts and/or springs too ($$$)
THANKS!
Jim
Old 09-21-2003, 06:09 PM
mbtoloczko's Avatar
sans SVX
Re: Custom Spring/Koni combo?
Let me know, Please. ...
THANKS!
I'm selling just springs which can be used with stock struts or with the Koni strut inserts. If you go with Koni, I'd recommend a higher spring rate than what my springs offer. You'll get even better handling than what you'd get with my springs. Porter has good springs in his soon to be available Koni strut/spring combo.
Mychailo
Visit my locker
