Old 09-13-2003, 09:57 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Interesting stuff relating with tire pressure
I've found that binding problem and the wierd thunking problem I had when coming to a complete stop had to do with tire pressure. One of my tires loses air a little over a month. My front passenger side tire had around 29 psi while the other front had 36 psi, while I leave the back ones at 32. The rear tires I keep filled to 32 psi, while the fronts I usually have at 38 psi. I noticed that after keeping even tire pressure the thunking went away and everything is fine. No more binding as well. Tranny shifts fine too. . I'm happy.
The tires I have are the Yokohama AVS S4-z's and they're pretty old but still have good tread on them. I should be fine this winter, and then i'll probably get some sumitomo htr+ I believe. I want the ES100's but I hear they're terrible for the snow.
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 09-14-2003, 10:43 AM
Szalkerous Szalkerous is offline
Send a message via AIM to Szalkerous
just for my 2 pennies, my front passenger tire was always the one to suffer as well. it was the first to get a bad bearing, the first to go out of balance, and by chance, the first to get a damage crack from the idiots who mounted my most recent set of tires. Now I have to inflate daily, which is no good for the tire... but I have to find a replacement OEM rim, and I'm very tight on cashola right now, so I just limp it along for the moment...
1994 SVX LSi - Black / Beige - 139k miles SOLD!
1999 Chevy Camaro Z28 - Black, 6-speed, hell of a ride.
2004 Chevy Silverado Z71 - Blue LT2 luxury package
Old 09-15-2003, 02:07 PM
mbtoloczko's Avatar
sans SVX
Re: Interesting stuff relating with tire pressure
Originally posted by TE1221
..., and then i'll probably get some sumitomo htr+ I believe. I want the ES100's but I hear they're terrible for the snow.
Just as an FYI, the HTR+ tires are fairly loud, at least compared to SP5000s. Good handling tire though.
Mychailo
Visit my locker
Old 09-15-2003, 06:02 PM
svx_commuter's Avatar
Now am going on four weeks waiting for the replacement ContiExtremeContact.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
