Old 09-24-2003, 08:34 AM
ww111
I hope I'm getting this right...
The tranny turns without the motor,
The motor turns without the tranny,
Put them together and no turn. It's GOT to be a mating problem. Somthing is binding and pulling the motor isn't going to help
Old 09-24-2003, 08:41 AM
solarsvx solarsvx is offline
Send a message via AIM to solarsvx
ww11 the transmsion is away from thh engine,
huck we look and inspected the conecting rods we took the oil pan off and they all where turning there was no metal shaving or pieces that drained from the oil ether.
huck would it still hyro lock if he spun all 4 cams, wouldnt that open it up the valves, he said all 4 cams turned, and it did not jump timing
2008 evo x with sss package
430 hp 380 torque stock turbo with basic bolt ons
12.56 @ 109 fully weighted 3,500 lbs
Old 09-24-2003, 09:36 AM
If one of the cylinders is full of fluid, on the compression stroke of the motor, it would cause the motor to lock, as both valves are closed at that point....but if you pull the spark plugs that would let it flush out the fluid as it turned over, then re-install the plugs and it should start back up....of course you need to find out where the fluid came from in the first place....
Hope you get it worked out soon, I really don't think it will turn out to be anything big, I'll have my fingers crossed for you,
Old 09-24-2003, 09:57 AM
Mr. Pockets's Avatar
Moderator
That was my thought, too. I had the same problem when I installed my tranny.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 09-24-2003, 04:24 PM
Are the following observations all correct ? : -
(1) " the engine is away from the transmissin " --- The engine will not turn when in no way connected with the transmission.
(2) The connecting rods turn " they all were turning ". --- The crankshaft will not turn ??????
(4) You have witnessed and confirmed the above and are not relying on simply what you have been told.
(5) A " mechanic/technition " can not find out why an internal combustion engine will not rotate and he is asking to be paid for his skill !
Old 09-30-2003, 07:20 AM
we think we have found the problem one of the timing cams gears that goes from the top cam to the bottom cam has a chipped tooth and causeing it to bind up , how it brok i have no clue but we are ordering a new cam for it to see if it is the problem, i will post somepics of it in the next few days
Old 10-02-2003, 04:34 AM
wawazat??'s Avatar
Yeah, I'm still around
Re: Got to be something simple........
Originally posted by Phil Hill
Just thinking "off the wall", how about a cam/lifter problem ?? Has a lifter shim slipped out and fouled the cam ?? I'm not familiar with the arrangement of these engines so maybe it doesn't have shims at all....... just a thought.
Hi Phil,
I saw your post and wanted to comment on it. The SVX, like the EJ22T of the same vintage, uses hydraulic lifters. Therefore, no lifter shims.
Todd
Down to none
Old 10-03-2003, 10:44 AM
just updated my locker guys with the damaged pics, check it out, i have them labeled
http://www.subaru-svx.net/photos/fil...rsvx/12212.JPG
http://www.subaru-svx.net/photos/fil...rsvx/12211.JPG
http://www.subaru-svx.net/photos/fil...rsvx/12209.JPG
Old 10-03-2003, 11:53 AM
wawazat??'s Avatar
Still need the cam James?
I haven't heard from you.
Todd
Down to none
Old 10-03-2003, 12:23 PM
todd i been trying to reach the mechanic, all week and no luck i think he died on me or somthing i called him 3 times yesterday and 2 times today so i have no clue if he ordered the part orhasentor what ? its fusterating
Old 10-05-2003, 11:10 PM
Noir's Avatar
Noir Noir is offline
re: hey solar
hey solarsvx, i hope that you are getting a good rate from that mechanic. it doesn't sound like that mechanic is treating you right. not returning calls and going on vacations without working something out with you. hope all goes well man. i'd be pissed if i were in your shoes.
