Old 08-29-2003, 10:39 AM
Robar Robar is offline
Power steering problem diagnosis help??
Greetings - hopefully one of you can provide some info/insight from a similar issue - I have not seen much about PS here.
92 Claret w/ 87K
Problem: Lots of noise turning the wheel at low RPM/Speed - not PS pump noise, but a "clunking" sound. The steering wheel stutters when turning it.
There are no leaks at all, and the fluid is full. I only noticed it when starting out, it seemed fine at driving speed. I did notice the smell of burning rubber a few times at low speed before the steering issue became noticable, and the pump makes a little whining noise, but nothing that compares to bad pumps I have experienced on other cars.
I question wether something is wrong in the steering rack, feeding back to the pump causing the stutters and noise, or if the pump is going out, causing the rack to behave this way?
Any help appreciated - not driving it till resolved, and getting ready to take her off the road for awhile and do a bunch of service issues and maybe a repaint too.
Old 09-01-2003, 12:06 PM
Motorsport-SVX's Avatar
Motorsport-SVX Motorsport-SVX is offline
check out www.planetsvx.com
have you had it up in the air
check out the rubber bushings that mount the
rack to the frame for starters....
Its possibly the racks bad inside, but its pretty rare
and with lower miles like that...
My mom will forever live in me and
never be forgotten, one day Ill see her again
CLICK the LINK below to Visit the SVX Store:
http://www.planetsvx.com
http://www.motorsportwarehouse.com/svx/sig2.jpg
Cars in the garage:
92 Toyota Soarer Single Turbo JDM RHD
70 Boss 302 Mustang 39k original miles
97 SVX Lsi
92 Liquid Silver Murano-ized (1st of its kind)
71 Cougar Xr7 Conv 351c 4v 4spd
69 SS Camaro 350
71 Nissan RHD Fairlady Z
70 Stang Fastback
70 Amc AMX 390
71 240z
89 Conquest TSi w/ 5.0 v8 swap
84 Mustang GT Turbo conv
"good, if it bleeds, we can kill it ....."
Old 09-01-2003, 01:55 PM
PS issues
Thanks, going to start checking it out later today - it doesn't sound like something mounting bushings would cause, hopefully its the belt or a pump bearing.
Old 09-01-2003, 02:09 PM
good luck
theres just really almost no way you should here a "clunk"
unless a rack bushing is gone, or look at your lower
control arm bushings. They are known to go bad on almost
any car after 100k miles....
If the rack is clunking internally, theres a real problem.
Could also be inner or outter tie rod ends somehow making
the noise, etc.
Best if you can try to put the front of the car up on jackstands,
have someone in the car
start it up and turn the steering wheel slowely from lock to lock.
Meanwhile be under the car with a droplite looking for the problem and noise in question.
Cars in the garage:
97 SVX Lsi
69 SS Camaro 350
70 Stang Fastback
70 Amc AMX 390
71 240z
Old 09-02-2003, 04:46 PM
Power steering
Thanks again - maybe "clunk" isn't the most accurate word - but its something close. It is definitely steering, not tie rods etc. - the wheel jumps a bit in your hand as you turn it and you can hear the pump/rack struggling, this is with the car standing still.
I plan to jack it up and see what happens from underneath if I eliminate the pump as the problem.
