Old 11-06-2003, 06:21 PM
mbtoloczko's Avatar
sans SVX
Originally posted by Phast SVX
todd im almost 100% posotive our rearends are r180 diffs...maybe if you swapped over to any other suby diff its 160 mm but didnt the SVX come with an 180?
phil
Phil,
Were you able to verify that the SVX has an r180 rear diff?
Mychailo
Visit my locker
Old 11-07-2003, 06:06 AM
wawazat??'s Avatar
Yeah, I'm still around
I don't think it's been resolved Mychailo
The cases are identical.
I've got a BUNCH of Subaru rear diffs in my garage (Legacy, Impreza, Legacy Turbo, SVX in a variety of ratios) and the cases that I have are physically the same. I'd be happy to disassemble them and compare/contrast IF I have a set of specs for what I'm looking for (R160 vs R180).
Todd
Down to none
Old 11-07-2003, 09:16 AM
svx_commuter's Avatar
Todds collecting rearends
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 11-07-2003, 11:07 AM
mbtoloczko's Avatar
sans SVX
Re: I don't think it's been resolved Mychailo
Todd
I was told by someone who really knows Subarus that the bolt spacing for the diff backing plate is wider for the two lower bolts on an R180 diff. I guess you haven't seen that?
Mychailo
Visit my locker
Old 11-07-2003, 01:40 PM
wawazat??'s Avatar
I've also got a rear diff from a '97 Impreza with the 1.8L engine. That diff is different. It looks similar, but the bolt spacing you mention is different, the vent location is different, and the bearing retention flages are different. I'm trying to pop the diff out and compare it to the other, previously mentioned rear diffs for comparisons sake, but am not sure how to remove it.
Todd
Down to none
Old 11-07-2003, 01:41 PM
wawazat??'s Avatar
Talking
shhhhhh..........don't tell my wife!
Down to none
