Old 08-21-2003, 10:01 AM
LarryGreen LarryGreen is offline
mean.green.machine
Transmission Cooler Install
I know this question has come up several times but I have not been able to find the detail I am looking for in any of the archives. So if someone wants to direct me to an existing response to this, that would be great.
I recently had my transmission fluid flushed with synthetic (I have a 96 with 40,000 miles - just purchased it. Missed my 92 that was totaled some years ago). I'm thinking about installing a cooler. All I need from someone who has installed one and has had positive results, are some detailed instructions on how to install it (or a strong suggestion that I have a transmission shop do it), and a suggestion on a size to buy (I've seen several in JC Whitney that are 3/4 inches wide with varying lengths and widths). It makes sense to me to bypass the existing radiator, but I'm flexible. In theory it doesnt seem like it would be difficult to install, but then again, I've gotten myself into trouble in the past with that attitude.
Oh, one last question - assuming I dont bypass the existing radiator, wouldnt I need to add another quart or so (over and above the recommended amount), since the fluid would now have a longer path to travel?
Thanks!
Old 08-21-2003, 02:07 PM
Larry
Welcome to the site.
There are some different configurations on the flows from the transmission to the coolers in the How-To Documents. It is on the upper right hand side of the page.
Most of the members have installed a filter (also in How-To) when they installed the cooler. This way you can install a temp gague sending unit in the filter and moniter the temps. Look the information over, and then ask your questions - I am sure you will have them. The stock cooler removes heat quicker than the air cooler, so I would run through it first, and then through the air cooler in the grill. Good luck. Oh, and yes, you will have to add some more fluid after installing what ever you do.
Old 08-21-2003, 08:39 PM
Invisible avatar
Smile
Welcome to the zoo, Larry, from another Ellicott City-ite.
I had a 16,000 GVW B&M cooler (50 bucks-ish on internet) installed by Dorsey transmission (85 bucks) over two years & 45K ago on my '92. Squeezed it between radiator & A/C condenser & is installed in parallel with original in-radiator cooler. There are 501 opinions in here as to what works best. No tranny demolition for me so far.
Regards, Ron.
'96 Grand Caravan - 240K
'01 Miata SE - 79K
Old 08-22-2003, 05:11 PM
CDG's Avatar
CDG CDG is offline
No front plate on My SVX
Send a message via MSN to CDG
There are 2 popular B&M coolers, Part# 70268, and 70255. I think the 70268 is the larger unit(I installed the larger unit) and will only fit between condenser and Rad. The smaller unit can actually be installed in front of the Condenser, you can even install 2 of them in front of condenser.
I have chosen the option of trany to Rad cooler to Air cooler back to trany. Filter still to be added.
FYI, the option between the condenser and Rad is very tight, and must be done carefully as not to let the new Trany cooler rub/vibrate against the radiator, or it will eventually cause a leak, and those rads are not cheap.
I have also seen the larger Trany cooler mounted under the front fender directly in front of the tire, facing down. Makes a lot of sense, but what out for those Parking lot curbs.
Chris G
92 Pearlie, sold @ ~209k miles. Now owned by Tim.
Current Ride, 1985 Honda Aero 80, stock 3024 klms
Old 11-29-2003, 05:13 PM
Motorsport-SVX's Avatar
Motorsport-SVX Motorsport-SVX is offline
check out www.planetsvx.com
check out this link
we did an install last week on a customers car
http://www.subaru-svx.net/forum/show...threadid=14343
My mom will forever live in me and
never be forgotten, one day Ill see her again
CLICK the LINK below to Visit the SVX Store:
http://www.planetsvx.com
http://www.motorsportwarehouse.com/svx/sig2.jpg
Cars in the garage:
92 Toyota Soarer Single Turbo JDM RHD
70 Boss 302 Mustang 39k original miles
97 SVX Lsi
92 Liquid Silver Murano-ized (1st of its kind)
71 Cougar Xr7 Conv 351c 4v 4spd
69 SS Camaro 350
71 Nissan RHD Fairlady Z
70 Stang Fastback
70 Amc AMX 390
71 240z
89 Conquest TSi w/ 5.0 v8 swap
84 Mustang GT Turbo conv
"good, if it bleeds, we can kill it ....."
