Old 08-17-2003, 12:38 AM
DavieGravy DavieGravy is offline
Bleeding the ps fluid.
What's the easiest way to completely drain all of the ps fluid? I'm still having problems with my PS fluid seeping out of the resevoir cap and it has been suggested by another member that I may have gotten water into the PS reservoir.
Thanks very much.
Out for good.
Old 08-17-2003, 08:11 AM
If you use a turkey baster, you can remove the fluid in the tank. If you change it a couple of time, it will be flushed out. I'm not sure of an easy way to drain the whole system. Maybe someone else does.
Old 08-17-2003, 08:42 AM
Thanks, but will doing that remove all the fluid? For instance, won't there will still be some in the pump and hoses?
Out for good.
Old 08-17-2003, 09:04 AM
Yes, but if you run it some, it will mix, and then get it flushed in two or three times. It is kind of a pain, but probably the easiest way.
Old 08-17-2003, 12:52 PM
OK. Thanks.
Out for good.
