Old 08-15-2003, 07:55 AM
milesmc214's Avatar
milesmc214 milesmc214 is offline
Send a message via AIM to milesmc214
Unhappy Help! I just got my car back and the gauges dont light up.
Can anyone help me find out whats wrong. I just got my car back from the tranny shop. After, I realized while driving at night that my gauges dont light up anymore and neither does the PRND321 on the shifter console. Any advice?
Old 08-15-2003, 10:53 AM
petesvx2's Avatar
petesvx2 petesvx2 is offline
chances are that it is just a fuse, check all the fuses under the kick panel and under the hood, that happened to me, and i also had no tail lights so check to see if those are on when you have your headlights on, my money is on a fuse though.
1992 Pearlie ... ??????k Sold 8/04
Kenwood KDC-MPV619
Wedgie Cupholder
1998 Acura Integra LS 74k Sold 1/07
2007 Toyota Tacoma Prerunner SR5 .04k!
2011 Toyota Tacoma Double Cab, 4x4 TRD Sport
Old 08-15-2003, 02:29 PM
milesmc214's Avatar
not the fuses
No Pete its not the fuses I have checked all fuses and they are fine my taillights are still functioning properly. I have no idea what the problem could be. Thanks for the help.
http://www.force-fedmotorsports.com/svxsig3333.jpg
--Miles Chatterji
Old 08-16-2003, 10:01 PM
SVXgarcia SVXgarcia is offline
Send a message via AIM to SVXgarcia
Its probably the dimmer!
That happened to me before, and I went nuts checking all the fuses. It turns out it was just the dimmer that wasnt all the way up. Check the dimmer, its located in the same arm(whatever you wanted to call it) where you make the trun signals. Make sure its up to the last dot. Let me know what happens
Old 08-16-2003, 10:14 PM
milesmc214's Avatar
Unhappy I dont know the problem.
Thanks everyone but its not the dimmer or the fuses I have absoultly no idea what it is I think may be the tranny people might have cut a wire or a wire broke or came loose or somthing. Could it be a relay?. Does anyone know where the gauge illumination wires could be? Can someone tell me how to take the gauges out and check them.
Again Thanks For the help.
--Miles
--Miles Chatterji
Old 08-16-2003, 10:25 PM
its a lot of work to take out the gauges, well not a lot but do you rally think its worth it. If you said that the lights on the shifter didnt light up either then I dont think its a problem with the guages but a bad connection, bring it back to the tranny shop tell and tell them what happened. Keep me posted
