Old 06-25-2003, 01:05 AM
overdalimit
Wheel Fitment
Can anyone tell me the specs for the SVX wheel (i.e bolt pattern, offset, and etc) I am looking to buy some aftermarket wheels but I need this to determine which ones fit properly and which ones don't. Thanks
Old 06-25-2003, 08:25 AM
elninoalex's Avatar
elninoalex elninoalex is offline
Registered Abuser
16 X 7.5 with 55 mm offset. Bolt pattern is 5 X 114.3mm A.K.A. 5 on 4.5". Try to find some with as much offset as you can, like 42+. I run a 46mm offset, 7" width and the outside edge is pretty much the same as stock. If you go too wide or too little offset, the back outsides will rub. 38mm offset, 7.5" width seems to be about the borderline.
Stephen
92 Ebony - Level 10/n2o REAR-ENDED
92 Teal - painted yellow/4.11 5spd/n2o SOLD
92 Claret - 4.44 SOLD
94 Barcelona - FWD SOLD
92 Ebony - 3.90 SOLD
94 Laguna ROLLING w/4.44s/Ecutune ECU +TCU/STI springs/Infiniti M45 rims
Old 06-25-2003, 10:37 AM
mbtoloczko's Avatar
sans SVX
Lower offsets can also affect stability during braking and acceleration. Even though +38 mm will work, the closer you are to the stock 55 mm offset, the better if you are looking to improve handling.
Mychailo
Visit my locker
