Old 06-24-2003, 09:36 PM
DavieGravy DavieGravy is offline
Howling sound came back
The howling sound I was talking about in this thread has come back as I knew it would.
I checked the intake tube for cracks and didn't see anything.
What's the likeliness that this is an exhaust leak?
Out for good.
Old 06-26-2003, 12:14 PM
Anyone know what this might be? Sometimes it's bad, other time's I can bearly hear it.
Old 06-26-2003, 07:52 PM
maximvsv's Avatar
maximvsv maximvsv is offline
I could use a nap...
Here's my guess. You're only hearing this when everything's heated up and has positive air pressure in the intake. My guess is that you have the entire housing for the filter just a bit loose, and that the heat expansion is opening a gap that is allowing the box to buzz, but only when the throttle is open enough to let enough air to pass. Now, it could be another connection, like the intake hose to the box or the throttle body, or it could be a crak in the hose somewhere, but that bottle sort of resonance usually means that the air is blowing perpendicular to the resonating volume. So, I'm guessing that the intake setup is loose at the connection where air gets in from the side of the engine compartment.
Old 06-27-2003, 02:51 PM
Thanks very much for you help maximvsv.
I didn't notice any cracks in the hose that goes form the intake box to the engine, although I couldn't remove the engine cover as the aftermarket clips I put in were being stubborn. Anyway, I dont' think it has cracks in it.
Additionally, I removed the housing (lower portion of the box) and checked the hose that runs into it from the side of the engine compartment. I didn't notice any cracks in this hose either when feeling around/looking inside it. I also didn't notice any cracks in the box itself. And the box (before I removed it) seemed like it was sitting firmly in place.
Could the rubber (that's part of the lower portion of the box) that surrounds the hole that the hose (from the side of the engine) fits into be the problem? Does this rubber surrounding get worn over time thus allowing air to seep through?
Also, how tight do the bolts need to be that hold the box in place and attach the intake hose to the box? I didn't want to overtighten them and crack the plastic.
Thanks again.
Old 06-27-2003, 02:52 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Howling sound
Sounds like a gremblin to me.
Old 06-27-2003, 10:16 PM
It still did it a bit today off and on.
Old 07-24-2003, 02:08 AM
maximvsv's Avatar
Originally posted by DavieGravy
...Also, how tight do the bolts need to be that hold the box in place and attach the intake hose to the box? I didn't want to overtighten them and crack the plastic.
I don't know. I'm sure there's something with torque specs on it, but I don't have any assembly manual or the like.
Old 07-24-2003, 04:58 AM
LarryIII LarryIII is offline
MAxim,
Let the werewolf out of the trunk. He has to go.
Larry III & The Beautiful Naviguesser
'19 Tungsten Pearl Outback 3.6R Ltd...."AISHA"
'08 Harvest Gold Outback 3.0L. L. L. Bean...."AIJOU"
'07 Gray Diamond Pearl Outback XT Ltd..."AH SO"
'05 White Pearl & Silver BAJA Turbo..."AH HA"
'97 Bordeaux Pearl SVX LSi..."SUBYDOO"
'94 White Pearl SVX LSi..."PEARLY"
'92 White Pearl SVX LSL w/touring pkg..."SVXY"
'92 Teal SVX LSL w/touring pkg..."ALCYONE"
'96 Polo Green LSi ... "MIDORI"
'00 Black Dodge VIPER RT-10... "VINNIE"
Engineers do it with precision.
English teachers are novel lovers.
Home: larrysingeriii@comcast.net
SVX FEVER, CATCH IT AT A MEET NEAR YOU !!
Old 07-24-2003, 08:18 AM
Thanks. I think it's sitting in there OK now.
Out for good.
Old 07-25-2003, 08:55 AM
maximvsv's Avatar
Originally posted by LarryIII
MAxim,
I can't. I'm allergic to dogs.
Besides, he shoulda' gone before we left...
Old 07-26-2003, 05:49 PM
The dogs of war!
Dave, from your description it sounds like the sound is occurring when the exhaust gas re circulator is operating. You might check the little pipe that runs up to the inlet manifold.
Old 07-26-2003, 11:56 PM
Thanks for the advice Harvey as the sound is still there. It seems louder on some occasions than others. (quite random)
Please forgive my ignorance but I must ask; Where's the inlet manifold and exactly where would the pipe run from? I assume from the bottom of the car up to the engine but I'm kind of car stupid.
Out for good.
