Old 06-24-2003, 08:29 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Shuddering around turning?
Hey all. I just had my transmission fluid changed this morning with a regular flush, gasket and screen change in the pan. I noticed at the end of the day I started getting a shuddering when accelerating and turning from a stop. It only happens when my wheel is turned enough, but its not from when I turn the wheel all the way.
Could it be a slipping gear? Otherwise it seems fine. I hope it will go away.
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 06-24-2003, 08:39 PM
Mr. Pockets's Avatar
Moderator
It sounds to me like the transfer clutch binding a little. There's a procedure that might cure this. It involves driving in tight figure-8s in a parking lot, but I don't remember the specifics.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 06-24-2003, 08:42 PM
Tim's Avatar
Tim Tim is offline
They showed me the tranny fluid when they took it out. It was a little dirty but nowhere near black, so I know my tranny isnt fried. The tranny does perform alot better now though. It seems to shift more effortlessly.
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 06-24-2003, 08:49 PM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
The shuttering can be a clue that your cooler is clogged. If the pressure gets too high in the cooler circuit, it can force open duty solinoid C engaging the rear and causing the binding you are talking about.
Doug
1994 LSi (4/93)
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Old 06-24-2003, 08:53 PM
Tim's Avatar
Tim Tim is offline
Thanks for the info. I'm not sure what to do but I know I'm not gonna drive my car that far unless I have to. Should I just get a B&M cooler and just bypass the whole cooler altogether?
Also, is the external filter for the transmission replaceable with the Permacool replacement filter?
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 06-24-2003, 09:51 PM
Invisible avatar
Question
Funny...today I experienced the same shuddering from the rear on both left & right hard turns into parking spaces. Until today the car has been flawless. Could heat have anything to do with this? Today it hit 93 degrees after the longest, coolest, wettest spring in recent mid-Atlantic history. All lubricants & fluids were changed less than 20K ago. Tranny fluid is still "pretty in pink". I've heard about the figure 8 gyrations, but....Why? What are the clutches attempting to do?
Ron (no more tight parking for me!)
'96 Grand Caravan - 240K
'01 Miata SE - 79K
Old 06-25-2003, 04:49 AM
LarryIII LarryIII is offline
Ron,
You put too many Boxi-O-Vino in the trunk. They are deforming the right rear inner fender well causing the well to rub on the right rear tire when your low speed 4WS engages for parking in tight spaces.
PS: How's that for an arcane explanation?
Larry III( trying to get into his ballet tights)
Larry III & The Beautiful Naviguesser
'19 Tungsten Pearl Outback 3.6R Ltd...."AISHA"
'08 Harvest Gold Outback 3.0L. L. L. Bean...."AIJOU"
'07 Gray Diamond Pearl Outback XT Ltd..."AH SO"
'05 White Pearl & Silver BAJA Turbo..."AH HA"
'97 Bordeaux Pearl SVX LSi..."SUBYDOO"
'94 White Pearl SVX LSi..."PEARLY"
'92 White Pearl SVX LSL w/touring pkg..."SVXY"
'92 Teal SVX LSL w/touring pkg..."ALCYONE"
'96 Polo Green LSi ... "MIDORI"
'00 Black Dodge VIPER RT-10... "VINNIE"
Engineers do it with precision.
English teachers are novel lovers.
Home: larrysingeriii@comcast.net
SVX FEVER, CATCH IT AT A MEET NEAR YOU !!
Old 06-25-2003, 07:01 AM
Tim's Avatar
Tim Tim is offline
I dont know what to do I'm just leaving my car at home because I dont want to damage or overheat anything until I know what to do.
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 06-25-2003, 07:47 AM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Car shuttering around turns
Is your power light flashing on start up? If it is you can find out the code. If its the Duty Sol. C like it sounds expect to pay 500 or so to get it fixed by a dealer. That's what it cost me plus I had to have a tranny mount replaced as well for another $200. A cooler won't do anything to help solve this situation. Driving it around dry turns if it is in 50-50 would be very bad. It would be like driving a part time 4x4 system on a dry road. You'll eat up your tranny quick!
Old 06-25-2003, 04:27 PM
Tim's Avatar
Tim Tim is offline
I'm not getting any codes on startup. I havent driven it at all today.
What kind of fuse should I put in to get the car into FWD mode? If it stops, is it the duty C selenoid?
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 06-25-2003, 05:37 PM
Tim's Avatar
Tim Tim is offline
I put the FWD fuse in and the shudering vanished. I'm assuming it no longer can be the blockage?
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 06-26-2003, 12:55 AM
mohrds's Avatar
If it goes away with the FWD fuse it, it is for sure blockage or a bad solinoid C. Lets hope for blockage.
Doug
1994 LSi (4/93)
2000 Ford Excursion
Old 06-26-2003, 07:08 AM
Tim's Avatar
Tim Tim is offline
Hopefully its the blockage. I'm going out to get a permacool filter and try backflushing the radiator to see where it will get me.
The people didn't change the campaign filter because they didnt know one existed and they couldnt get a part number.
BOoooo.... "Is your car some kind of european prototype that you imported?"
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 06-26-2003, 02:41 PM
Tim's Avatar
Tim Tim is offline
Hey can someone show me a diagram of where the hoses from the lines of the transmission cooler to the filter?
I'm thinking maybe they hooked it up backwards and it could have been the case.
Also the line from the transmission supposed to run to the filter first, then the radiator, then back to the tranny?
It's really urgent I'm outside under the car looking at everything and I want to make sure where all the lines run.
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 06-26-2003, 02:59 PM
mbtoloczko's Avatar
sans SVX
Search in the Tech forum. There's a posting this topic in there.
Mychailo
Visit my locker
