Almost 100,000 miles
My car has 700 miles before it turns 100,000 miles old. I plan to put on a tranmission cooler, can you guys recommend a website where I can find a good cooler that fits perfectly?
The other thing I wanted to ask was what do you recommed I do to my car when it turns 100,000miles? what type of tune-ups? should I do the spark plugs? if so which type are worth it? thanks guys |
Almost at 100k
You realize that you do need to go 100mph for the 100k celebration don't ya?
As for the tranny cooler www.summitracing.com sells quite a few that should work for ya. I have a B&M 19,000gvw 3/4" cooler between my condens and rad. I see temps that will just keep going up above 200 degrees in stop and go traffic and some large long mountaions but cruised decently on the highway (140-170). In the winter it rarely gets up past normal op. temp which is about 140. Usually around 120-130. I'd recommend a gauge to so you know when your frying the ATF. I have a norsdouq???? digital gauge (green almost matches the color of the svx's lights) with the sender in my pan. Others recommend it elsewhere which is probably easier too. As for plugs NGK all the way baby. 1. They are what Subaru recommends, 2. They are fairly cheap, 3. I've never had an issue with one in any of my Subarus. Bosch always seem t increase the boxer hesitation to me. Do some searching on the sight you'll come up with a weath of info on both though questions though. Congrats on the milestone. Be sure to register it in the Subaru High Mileage Club!
British vehicles are my last ditch attempt to keep the nasty Italian thoughts in my mind at bay. So far its working. |
Re: Almost at 100k
Re: Re: Almost at 100k
Re: Re: Re: Almost at 100k
-Bill p.s. do you have the URL for the Subaru High Mileage Club?
over 100k
http://hometown.aol.com/nv1z/subaruhighmileage.html
The sender was done by a local shop. It looks like they took off the pan, drilled a hole and welded a fitting onto the inside of the pan then used a bunch of tar like stuff on the outside to make sure it sealed. I've had no problems with it in the year or so its been on.
Thread Tools | |
Display Modes | |
