Old 06-20-2003, 08:37 PM
ALsvx
Transmission Gremlins??
This afternoon, after work, I got in my car and started to pull onto the main road and the car just slowly creped onto the road like it was stuck in 3rd gear??? Tried to downshift into 1st and 2nd and nothing happened…. It ran all right when it got up some speed but it did this the whole way home.
When I got home, changed and went back out to look at it… I started it up and it drove it around the block it shifted normally???? What’s up with that!!! Has this happened to anyone else?? I think I’ve got gremlins!
Bill
Old 06-21-2003, 08:36 AM
svxeno
Once mine would only use 3rd & 4th. It turned out to be a duty solenoid. I'm sorry I can't recall which one. Might be worth checking further into. or...
Place hands on the tranny case and scream "BAD TRANNY DEMONS BE GONE!!! It can't hurt but the neighbors will look at you funny.
Good luck.
Randy ii
Old 06-21-2003, 06:21 PM
Jamsvx's Avatar
Jamsvx Jamsvx is offline
Send a message via ICQ to Jamsvx Send a message via Yahoo to Jamsvx
[/B]
Brilliant!
1992 charcoal grey SVX:
27 August 2002 to 27 January 2004 - she will be missed
Was back in Sydney for a while but not hot enough so now in Dubai! Has it been that long since I owned SVX-33H!
Old 06-21-2003, 06:50 PM
Re: Transmission Gremlins??
Bill
If there is a problem with either shift solenoid, the trans will defualt to just using 3 rd, by turning both solenoids off.
Do a code check to see if it is the shift solenoids.
