Old 06-16-2003, 02:48 AM
The Molinator
Question slight PING!
Is it ok that I'm experiencing a slight ping in my svx when accelerating (moderately) off the line? It is not very frequent, nor is it very severe. So, should I be concerned? It's not producing a code (which I'm told the knock sensor will do).
ANY THOUGHTS will be appreciated!
Jim
Old 06-16-2003, 08:21 AM
jsvxstyle jsvxstyle is offline
MINEZ BETTER
use 91 octane or higher.
white leathers, h.i.d, ecutune S/C stage 4, 14 inch 2piece rotors big brake kit., , msd ignition, c/f dash kit, front spoiler,carbon fiber jdm rearc wing,19 inch rims, nos, , aem fuel regulater, koni-gc package, ported cylinder heads, supercharger cams,solid buck and shims,wrx sti intake valve and exhaust valves,& valve springs, gas analizer,water injection, exhaust temp gauge, idiglo gauges, shift kit, , remote start, all automatic windows,2.5 inch true dual exhaust system with crossover, and 2 borla stainless steal muffler,air filter velocity air stack 3inch to 6 for air filtre, group n mounts, momo steering wheel, dyno will happan soon
Old 06-16-2003, 12:06 PM
That was my first thought. Are you using 91 or higher octane fuel? If not, I would change now.
Old 06-16-2003, 09:22 PM
michael's Avatar
michael michael is offline
What Potholes ???
ping
how's your oil? try an oil change that usually cures my engine noises, It never hurts.
Old 06-17-2003, 10:26 AM
The Molinator
PING
I use 91 always + now I'm using about one ounce of fuel treatment per tank of gas. I don't know if that increases or decreases octane? (I haven't had intermittent rough idle problem for about 2 weeks now, since I dumped fuel treatment in a tank + now add the 1 OZ. per tank!)
Jim
Old 06-19-2003, 02:41 PM
The Molinator
Plus, I just passed my smog check with flying colors.
Does the ping mean anything, guys or are there too many possibilites to name?
THANKS!
P.S. I did just change my oil (Redline 10/30)!!
Jim
