Old 06-12-2003, 08:33 AM
alacrity024
Who has FSM's and a scanner? dropspring installation..
hey, who wants to help me out?
i just won the auction on Troy's K&B's and I'm planning to install them myself. who can tell me how to do it? can anyone scan in the pages from their FSM and post them? thanks in advance
-adam
Old 06-12-2003, 11:45 AM
mbtoloczko's Avatar
sans SVX
Re: Here's how I did it...
Strut spring replacement procedure
*Pre-job prep*
1) About a week before you plan to do the work, pull off all the wheels, clean the exposed threads on the strut-to-knuckle bolts using a wire brush, and put some PB Blaster or Liquid Wrench on the nuts and threads of the bolts securing the struts to the suspension knuckles. Soak them as best as you can. Wipe up excess. This will make life much easier when you try to remove these nuts.
2) You will need a strut spring compressor. You can rent these at many auto parts stores for about $10 or less.
3) Make sure that you have a wrench or socket that will fit on the bolt heads for the bolts that tighten the springs down on the strut spring compressor.
4) You will need a very deep well (3 inches) 17 mm socket with flats on the outside to turn it with a crescent or box end wrench.
5) You will need a long (4 inches) 6 mm allen wrench or allen socket.
6) You will need a 1/4" dia rattail file to elongate the strut mount holes in the front strut mount towers to reclaim some of the caster you are going to loose by dropping the front end 1" relative to the rear.
7) You will need about 10 feet of bailing wire to hold the suspension knuckles in place when you disconnect the struts from the suspension knuckles.
8) You will need about 5 minutes of someone's time to help you remove and reinstall the struts when the last nut is removed/attached. They will be removing or installing the last few nuts (which you will have already loosened). They will not get dirty.
9) From the factory, there is no camber control on the rear suspension. There are places that sell generic camber bolts that will replace the upper strut-to-knuckle bolt and permit rear camber adjustment. This can be handy for getting the best alignment for handling. There is a kit made by Speciality Products Company. http://www.specprod.com/ You can call them to find a local seller. The cost for the kit should be no more than $30 + shipping.
*Front strut springs*
1) Put the front end on jackstands and remove the front wheels. Please be sure that the jackstands are supporting the car by the frame and not the control arms.
2) Using a wire brush, again clean the exposed threads on the strut-to-knuckle bolts and then apply more PB blaster.
3) Remove the bolts securing the brake lines (12 mm) and ABS sensor leads (12 mm) to the struts.
4) Remove the nut (14 mm) securing the sway bar links to the struts. You will need to put a 14 mm open end wrench on the sway bar link ball joints to keep them from turning when you loosen the nuts.
5) Match mark the upper strut-to-knuckle bolt face to the strut as this bolt controls the camber of the front wheels.
6) Loosen the nuts (19 mm) securing the strut to the knuckle. They will likely be very tight. If you have access to a powerful airwrench, it should be pretty easy to loosen them. If you only have handtools, if you pre-soaked nuts and threads with PB Blaster, then you have a good chance of removing them with a standard breaker bar, but an extension may be necessary.
7) Once you loosen the strut-to-knuckle nuts, you can remove them. Don't remove the bolts yet.
8) When you finally disconnect the strut from the suspension knuckle, the knuckle is going to want to flop out and back, and the knuckle along with the control arm will want to drop down. You don't want to let this happen. First, prop up the control arm. I used a milk crate a few 2x4s. Next, using the bailing wire, secure the position of the suspension knuckle by wrapping the wire around the knuckle below the strut mounting point and then attach the bailing wire to the frame of the car somewhere near the front of the car and inboard of the knuckle position.
9) Open the hood of the car and pop the dust cover off the top of the strut tower. This will expose the strut mounting nuts and the top of the strut mount itself.
10) Loosen the three nuts (12 mm) securing the strut to the strut tower.
11) Now remove the bolts securing the strut to the suspension knuckle. You may have to twist the upper bolt to get it to slide out. The bolts come out easily if you apply a little inward pressure on the strut and tap the bolts with a soft face hammer. Its most probable that friction between the strut and the suspension knuckle will keep the parts from separating.
12) Now get the friend to help you. Have them remove the three nuts securing the strut to the strut tower. You will need to lift up on the strut so that they can remove the nuts by hand.
13) The strut can now be tilted inward somewhat at the bottom and pulled loose from the suspension knuckle. If you properly secured the knuckle with bailing wire, it should not flop much at all.
14) The strut is fairly heavy. As you drop it out from the backside of the fender well, you will need to pull the brake line out of the way.
15) Whew. You've got the strut out the car, and now you can switch out the strut spring. Before you do that, make note of a few things.
A) Pull up the strut shaft boot and have a look at the strut itself. Is it leaking oil? Might as well replace the strut now if its leaking.
B) Note the position of the upper spring mount. There should be the words "Outside" on it. This position should line up with the strut-to-knuckle mounting flanges when you look down the strut from the top.
C) Note the position of the spring in the lower strut mount. Note where the pigtail ends.
D) Note that the upper strut mount bolt heads do not make an equilateral triangle. This is because the strut mount attaches to the strut tower in a particular orientation.
16) Get that strut spring compressor and use it.
17) Once the springs are compressed so that there is no load on the strut, pop the cap off the top of the upper strut mount, put that deep well 17 mm socket on the nut inside and put the 6 mm allen on the shaft end. Loosen and remove the nut. Please note that there is a bearing inside the strut mount and that you should not let any dirt or debris enter in there.
18) Once the nut is off, you can pull the pieces off the strut. Note how everything comes apart.
19) Pull the spring out, release the strut spring compressor, grab the replacement front spring, and compress it.
20) Reassemble the strut pieces. As you release the spring, make sure that the spring and the upper spring mount are correctly aligned relative to the bottom of the strut.
21) Grab that rattail file. Elongate the strut tower mounting holes in the direction of the rear of the car. You can elongate the holes by about 0.15 inches. This doesn't sound like much, but dropping the front end by 1" relative to the rear will decrease the caster by about 0.5 degrees. Elongating the holes by 0.15" and mounting the strut at the back of the holes will add about 0.35 degrees, so your total caster lose will be only about 0.15 degrees.
21) Reinstall the strut into the car. You will need your friend's help to put on a few of the strut-to-strut tower nuts while you hold the strut in position.
22) Reinstall the strut-to-knuckle bolts. Set the position of the upper bolt as per the match mark.
23) Reinstall reinstall remaining nuts and bolts.
24) That's it for the front.
*Rear strut spring replacement*
1) Disassemble the rear of the car interior.
A) Pull the rear seat bottom. It is secured by two tabs at the bottom front of the seat.
B) Pull the side panels. There are 2 fake plastic screws on each panel that need to be removed. You will need to tilt the seat-back forward to see one of these screws. Then the panel just pops off. Some of the buttons securing the panel to the car may stick to the car rather than come off with the panel. You will need to remove those from the car and reinstall them on the panel.
C) Pull the rear deck cover. There are two phillips head screws securing it. It slides forward to be removed.
1) Jack up rear of car, put on jackstands, and remove wheels.
3) Remove the bolts securing the brake lines (12 mm) to the struts.
4) Loosen the nuts (19 mm) securing the strut to the knuckle. They will likely be very tight. If you have access to a powerful airwrench, it should be pretty easy to loosen them. If you only have handtools, if you pre-soaked nuts and threads with PB Blaster, then you have a good chance of removing them with a standard breaker bar.
5) Once you loosen the strut-to-knuckle nuts, you can remove them. Don't remove the bolts yet.
6) When you finally disconnect the strut from the suspension knuckle, the knuckle is going to want to flop out and the knuckle will want to drop down. You don't want to let this happen. The easiest way to prevent this is to just prop up the bottom of the knuckle. It will still flop out slightly. You could also secure the knuckle with some bailing wire as you did in the front, but be sure to leave room to pull the strut out which will come out from the front of the fender well.
7) Climb in the car and loosen the three nuts (12 mm) securing the strut to the strut tower.
8) Now remove the bolts securing the strut to the suspension knuckle. The bolts come out easily if you apply a little inward pressure on the strut and tap the bolts with a soft face hammer. Its most probable that friction between the strut and the suspension knuckle will keep the parts from separating.
9) Now get the friend to help you. Have them remove the three nuts securing the strut to the strut tower. You will need to lift up on the strut so that they can remove the nuts by hand.
10) The strut can now be tilted inward somewhat at the bottom and pulled loose from the suspension knuckle. If you properly secured the knuckle with bailing wire, it should not flop much at all.
11) The strut is fairly heavy. As you drop it out from the frontside of the fender well, you will need to pull the brake line out of the way.
12) Whew. You've got the strut out the car, and now you can switch out the strut spring. Before you do that, make note of a few things.
B) Is the upper strut mount rusted to all hell? If so, you may want to consider replacing it. They are about $85/ea from 1stsubaruparts.com.
C) Note the position of the upper strut mount relative to the strut. There should be a notch on the outside of the upper strut mount. This notch faces outward and should line up with the strut-to-knuckle mounting flanges when you look down the strut from the top.
13) Get that strut spring compressor and use it.
14) Once the spring is compressed so that there is no load on the strut, put that deep well 17 mm socket on the nut at the top of the strut, and put the 6 mm allen on the shaft end. Loosen and remove the nut.
15) Once the nut is off, you can pull the pieces off the strut. Note how everything comes apart.
16) Inspect the upper spring mount rubber seat. Its metal coated with rubber. If yours is like mine, the metal inside will be rusting badly at the point where the spring coil ends. If so, you can either replace it or reuse it. If you decide to reuse it, you will need to pry the seat out of the upper strut mount and reposition the seat so that it lines up properly with the new spring when you reassemble the strut pieces.
17) Pull the spring out, release the strut spring compressor, grab the replacement rear spring, and compress it.
18) Reassemble the strut pieces. As you release the spring, make sure that the spring, the upper spring seat (if reusing a rusted one), and the upper strut mount are correctly aligned.
19) Reinstall the strut into the car. You will need your friend's help to put on a few of the strut-to-strut tower nuts while you hold the strut in position.
20) Reinstall the strut-to-knuckle bolts. If you purchased the aftermarket camber adjusting bolt, install it now as per the instructions. Set the camber at a neutral position.
21) Reinstall reinstall remaining nuts and bolts.
22) Reassemble the interior.
23) That's it for the rear.
*Post installation*
Take the car in for an alignment. Set front camber to -0.5 deg, front toe to 0". Set rear camber to -1.0 degree, rear toe to 0". Check front caster to see if its within spec.
Mychailo
Visit my locker
Old 06-12-2003, 12:53 PM
I talked to Troy and I will try to get something for you on brakes as well as the springs.
Old 06-12-2003, 01:49 PM
alacrity024
huh? brakes? i'm already pretty adept with the svx brake system
-adam
Old 06-12-2003, 02:20 PM
Did you get enough on the springs installation? If so, I won't bother.
Old 06-12-2003, 02:23 PM
lee lee is offline
Re: Re: Here's how I did it...
...snip....
What a write up! Never having done it (yet), I cut and pasted the whole text into a file so I won't lose it (hopefully). Don't know when I might need it, but would like to say thanks way in advance.
Old 06-13-2003, 10:26 AM
alacrity024
wow.. that's a lotta information.. now i'm not really looking forward to installing these things.. this could take a couple of days. i'll consider paying someone else to do it, but i think i can probably manage.
as far as brakes go, i'm familiar with removal of calipers, pads and rotors, but not with caliper rebuilding procedures. if you have a good writeup on that, send away..
also, any information you might have on a R&R job on the Master Cylinder would be appreciated.. how do you tell if it's in need to repair?
-adam
Old 06-13-2003, 10:47 AM
mbtoloczko's Avatar
sans SVX
-adam
It took me two afternoons to do the job. There really aren't many nuts and bolts to remove, and overall, the job is pretty simple. Its just time consuming. Compressing and decompressing the springs was a royal PITA using handtools and used the largest fraction of that time. If you have an airwrench, the entire job could easily be completed in one afternoon. The number 2 time killer was getting the strut-to-knuckle nuts loose. With handtools, there are less than optimum wrench positions, so I had to experiment with positions until I found one that I was able to apply sufficient torque to break the nut loose. Again, an airwrench here would have been a real time saver.
Mychailo
Visit my locker
Old 06-13-2003, 11:02 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Awesome job!
Mychailo,
You get me vote for the inaugural entry in the "how to" section that another thread is trying to work up support for. Add pics in the "how to" locker and "spring removal/installation" wins the Oscar! (the Oscar winner for the following vote being Huck's soon to be released "timing belt replacement")
-Bill (thinking seriously about unleashing the Liquid Wrench this weekend....)
Retired NASA Rocket Scientist
Center Network Member #989
Old 06-13-2003, 11:29 AM
svx_commuter's Avatar
Hey Mychailo that is a very nice thoughtful write up. Lots of detail for a great install. I would like to add my thoughts.
I have used this to put the camber back the way it was. It comes out very close. Use a calipher to measure the distance from the front of the hub to the back of the strut by the camber adjustment bolt. I have a picture somewhere..... Of course the camber would be realigned since the springs are shorter so it is not that critical here.
How did you work the spring compressors? I found I had to drive the claws into the spring coil to get enough length out of the screw thread. Without that "driving in" I wasn't able to move the ends of the spring until the center was overcompressed. I like the Sears compressor a lot but don't own one.
I break the top nut loose from the strut shaft before I start to remove the strut. I also tighten it again after it's back in. Depending on how long the nut has been in there it could be tight. The car is a much better vise than trying to hold the strut out of the car. What's your experience with that?
I have used wood to support the disk/ hub assy.
Now I have to read the rest of thread.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 06-13-2003, 01:57 PM
rufus's Avatar
rufus rufus is offline
I look like Gordon
This job is not as bad as it sounds. Definitely break all the big top bolts loose before removing the strut assemblies.
Some other helpful hints:
When it comes time to release the tension on the spring compressor, clamp the bottom of the spring to the spring perch tightly (in the right position) with a pair of vise grips. This will keep it from spinning around in the perch which it will very much want to do.
I was able to achieve the appropriate torque on the strut top bolt without the allen key, once the strut was back on the car and lowered all the way to the floor, on two different SVXs. Do not try this before all the weight is back on the strut though, or you will spin the spring on the lower perch and you will not be happy. YMMV on this one.
When putting the compressors on the spring, space them evenly each 90 degrees from the point where the spring ends at the bottom. This will help the bottom of the spring lift up evenly and give you enough room to compress the spring without having to pound the top "hook" of the compressor in between the coils at the top.
Have a helper put a long bar through one of the bottom holes in the strut to hold it while you are cranking the compressor down. I laid it sideways on a piece of wood when I did this. This is easier and much safer than trying to hold the assembly in place yourself. I have scars to prove it.
Good luck.
First the smiles, then the lies. Last comes gunfire.
Old 06-13-2003, 02:49 PM
mbtoloczko's Avatar
sans SVX
I didn't find it necessary to jam the claw inbetween the coils at the top and bottom of the spring. I just had to compress the inner coils a large amount. That's probably why it took me so long to compress/decompress the springs. :-)
hehe. Yeah, I'll admit that's what I did. I think its ok to do in the front, but my feeling is that using the strut mount in the rear for leverage could potentially damage the rubber bushing, so I didn't include it in the instructions. I don't want anyone writing back saying they ripped the rubber bushing while trying to loosen the strut-to-strut mount nut using this technique.
Mychailo
Visit my locker
Old 06-14-2003, 06:00 PM
overdalimit
Headless Strut Man
Wanna know how to replace the struts the easy way???
PAY A SHOP TO DO IT!.......I owned a repair shop and called myself changing a set of struts with that dreaded parts store spring compressor. It came loose while I had the spring compressed and I almost lost my head. The spring shot over 30 feet in the air and hit the roof of my metal shop with more force than it left the ground and landed 6 inches from my customers Cadillac....I threw those shocks in the trunk and drove to a alignment shop so fast I almost got whiplash.. They had a special $600.00 compressor and did it safely.
