Old 07-29-2008, 02:47 PM
kwren's Avatar
kwren kwren is offline
Re: Beav, Harvey, Trevor, experience needed
Originally Posted by dromano View Post
In this thread Beav said he put O rings on the bolts between the washer & valve cover. Just wanted to know if leaks or no leaks.
I believe the bolts actually bottom out for the valve covers. Not 100% sure. If that is the case...
adding a thin washer would put more pressure on the seals for each bolt and also would increase the pressure on the valve cover gaskets that fit on the edges of the covers.
Old 07-29-2008, 05:02 PM
I have not meaured clearances but it also brings the valve covers that much closer to the cams as well... Just something to think about
Old 07-29-2008, 05:54 PM
dromano's Avatar
dromano dromano is offline
Does anyone know, has Beav left the site?
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited
2012 Outback 3.6R Limited!
