Old 06-05-2003, 07:31 AM
mhl0125 mhl0125 is offline
Send a message via AIM to mhl0125 Send a message via Yahoo to mhl0125
Blower/Heating/AC/Defroster
Several problems...
When I put on the a/c, heat, or defroster there is an itial thumping noise like the air flow door is opening or closing with a thud...any ideas?
The windows were steamed up yesterday from the rain and when I push on the defrosters with the temp at 65 degrees, it only cleared the bottom few inches of the windshield. Eventually I changed it to heat (72 degrees) and it cleared. How should the windshield be defogged?
There doesn't seem to be a lot of force blowing out of the vents at any of the three speeds. Air is blowinmg out at each speed, but compared to other cars I have, this seems considerably less. Is this normal?
Finally, I had a new compressor and receiver/drier installed yesterday. It still doesn't feel cold enough. Could there be another issue with the system? It was only in the high 50's yesterday. Could it be that it has to be warmer outside before it starts blowing colder inside?
Any advice on any of these issues is appreciated.
This system is driving me nuts!!!!!!
Michael
1994 Barcelona Red SVX-LSI
Two-owner:169K
1995 Emerald Green SVX L AWD
#80 - Custom intake w/cone filter
99K with killer stereo system
2002 Acura MDX-Touring Edition w/navigation
2008 Toyota Prius
1987 Mercedes Benz 560SL
Old 06-05-2003, 07:34 AM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Check the air door control motors, they have a habit of coming loose and not fully operating their doors. Look up under the dash on either side, ther should be a box, slightly smaller than a pack of cigs. Try wiggling it and if loose, tighten the screws.
