Old 06-06-2003, 03:57 PM
From my personal experience, during warmup the TC will not lock until 140°F-150°F. If it's cool outside (10°F or so) the tranny will cool back down to under 100°F. As soon as it dips below that the TC unlocks and it starts heating up again and the cycle repeats.
(and as I've said before I don't have an extra tranny cooler)
Old 06-06-2003, 08:38 PM
svxxx26's Avatar
svxxx26 svxxx26 is offline
Headed to Texas...
Re: Re: Controlled cooling
Originally posted by svx_commuter
I used a diverter valve so that the AFT by-passes the aux cooler in the winter.
Hmmmmmmmm...interesting! Can you describe this "diverter valve"? is it something you switch manually?
Sounds like a good idea after hearing the reports of TC unlocking in cooler weather. I have a cooler to install but not really looking forward to the TC "cycling" on and off.
Jerry
2005 Baja Turbo
2008 Ford Crown Victoria Police Interceptor
jnj7707@yahoo.com
Old 06-07-2003, 09:11 AM
mbtoloczko's Avatar
sans SVX
Re: Re: Re: Controlled cooling
There are by-pass thermostats for oil cooler systems that can be purchased. The inlet and outlet lines for the oil cooler pass through it. Hayden makes one that begins opening at 160F. I've got one but haven't installed it. I'm worried that because the oil cooler inlet and outlet lines pass through the thermostat which is a big hunk of metal, the cooled oil is going to get heated significantly by the hot oil.
Mychailo
Visit my locker
Old 06-08-2003, 11:51 AM
svxxx26's Avatar
Headed to Texas...
I guess that's a possibility...but not knowing where the diverter valve IS, don't know if the heat it returns to the cooled ATF would ever be significant.
Why do BOTH inlet and outlet lines need to go thru it?
Anyway, I don't seem to be any closer to having this issue settled in my head.
Going on personal experience, I've driven my SVX mostly in warmer temps with no aux cooler at all. I have not noticed any bad things happening in hot driving - of course if I had a tranny temp guage I might be more concerned!
Obviously the tranny needs some additional cooling capacity but not TOO much more, or it starts affecting the operation at the other extreme (too cool).
So the answer to me seems to be installing a conservative cooler with some way to thermostatically control it so that overcooling doesn't occur.
Install in series with the stock cooler? Parallel? Bypass it?
Jerry
2005 Baja Turbo
jnj7707@yahoo.com
Old 06-08-2003, 01:57 PM
mbtoloczko's Avatar
sans SVX
Yeah, I agree, it may insignificantly heat the cooled ATF. The only way to know is to try it. The next time I feel like getting covered in ATF, I'll climb under the car and install it, and then we'll have an answer. :-)
Both lines need to pass through the thermostat so that when the ATF is cold, the thermostat can send the ATF straight back to the tranny. It can't just stop the flow. NG. :-)
I've got one of the B&M 18,000 GVW ATF coolers sandwiched between the A/C condensor and the radiator and a thermostat that reads the ATF temp going into the tranny. Today, in 90F temps with the A/C running, the ATF inlet temperature sits at about 165F in traffic. If I get onto the freeway where the TC can lock, it cools to about 150F. Just about right IMHO, but I have seen it climb to 180F a few times when I start driving aggressively in stop-and-go traffic.
In series with stock is my recommendation. The stock cooler helps to warm the ATF quickly, but maybe with an ATF thermostat, the stock cooler could be by-passed entirely.
[/B][/QUOTE]
Mychailo
Visit my locker
Old 06-09-2003, 06:31 PM
svxxx26's Avatar
Headed to Texas...
Well, I've had my cooler sitting on the shelf in the garage for about 4 years now...guess I'll bite the bullet and put the thing on.
I like the idea of having a thermostat too.
Thanks for the all the info
Jerry
2005 Baja Turbo
jnj7707@yahoo.com
Old 06-29-2003, 06:44 PM
The Molinator
Cool small cooler IN
I opted for the locally available (Hadyn) small plate cooler between the AC condensor/radiator, about $50. I'm hard up financially now or I would have installed (driver side/in front of wheel) the B&M HiTek. It makes the best sense, because of the thermostatic control - only comes on when you need it + has its own air source! BUT, doesn't get too cold here + (like I said) $50 is alot less than $190. Thanks for your inputs!
P.S. I installed after loosening top of radiator (only). Cut included hose - one about 4 inches shorter than the other piece. Attached these to cooler. Tipped radiator toward engine. Slid cooler in between with hoses facing up and bending toward driver side. Positioned hoses down side of radiator to area just in front of campaign filter (later attached one to exit [center]nipple of AT oil filter, one attached [using aluminum tubing] to the hose removed from center filter nipple). I placed nylon "straps" thru AC condensor, thru oil cooler and allowed point of nylon to protrude about 1/8 inch out other side of AT oil cooler. I used a long needle nose plier to hold the foam pads just in position over the projecting nylon point. After all four were in position, I tipped the radiator forward against the pads. Pushed all the way thru radiator, pushed on retainers and clipped excess. Seemed to work easily and well. Hope this helps somebody!
Jim
