Old 05-26-2003, 11:34 PM
overdalimit
Angry Air Conditioning Problem
OK GUYS! I NEED UR HELP. MY 95 SVX A/C IS ACTING UP..WHEN I GET IN THE CAR, START IT AND TURN ON THE A/C BY PRESSING THE AUTO BUTTON IT JUST SITS THERES AND DOES NOTHING THEN ALL OF THE SUDDEN IT'LL BLOW HARD AS HELL 4 2 SECONDS THEN GO BACK TO LOW SPEED THEN ALL OF THE SUDDEN IT'LL STARTING BLOWING FULL BLAST AGAIN. IT JUST KEEPS REPEATING THIS CYCLE. ALSO, DURING A/C OPERATION THE BLOWER WILL STAY ON BUT THE COMPRESSOR WILL JUST TURN OFF THEN ALL OF THE SUDDEN IT'LL KICK BACK ON AGAIN. NOW, I CAN MAKE THE BLOWER COME ON WHATEVER SPEED I CHOOSE BY PRESSING THE APPROPRIATE BLOWER SPEED BUTTON BUT THE COMPRESSOR WON'T COME ON UNTIL IT GETS READY WHICH CAN BE ANYWHERE FROM 15 SECONDS TO A COUPLE OF MINUTES. SOMEONE PLEASE HELP...I'M TIRED OF GOING FROM COOLING TO COMPLETE HEAT IN A MATTER OF SECONDS.
RECENT WORK DONE: A/C COMPRESSOR W/ DRIER. I ADDED THIS FOR INFORMATIONAL PURPOSES ONLY..IT WAS DOING THE SAME EXACT THING WITH THE OLD COMPRESSOR. NO, I DIDN'T CHANGE THE COMPRESSOR THINKING THAT WAS THE PROBLEM, IT WAS GETTING NOISY AND GOING OUT.
Old 05-27-2003, 07:33 PM
lee lee is offline
Caps key stuck?
have you tried the diagnostics? look in the attached file.
Old 05-27-2003, 09:13 PM
Wow, I haven't seen that pdf file before. I like it. I think I'm going to calibrate my temperature settings tomorrow. I think I'm 2 degrees too warm.
BTW, my AC is doing the same thing.
Old 08-09-2003, 12:02 PM
Motorsport-SVX's Avatar
Motorsport-SVX Motorsport-SVX is offline
check out www.planetsvx.com
similar problem
something wierd started on my 92 today..
AC was working fine, .....then outta the blue after
sitting parked, but idling for about 15 min in 105
degree heat the blower quit blowing.
My AC kicks on, All AC lights on the dash all lite
up fine just the BLOWER doesnt "blow" thru any of
the vents on ANY with any buttons pushed....
Checked all my fuses, not sure what else to try to be
looking for.......
any ideas ?
My mom will forever live in me and
never be forgotten, one day Ill see her again
CLICK the LINK below to Visit the SVX Store:
http://www.planetsvx.com
http://www.motorsportwarehouse.com/svx/sig2.jpg
Cars in the garage:
92 Toyota Soarer Single Turbo JDM RHD
70 Boss 302 Mustang 39k original miles
97 SVX Lsi
92 Liquid Silver Murano-ized (1st of its kind)
71 Cougar Xr7 Conv 351c 4v 4spd
69 SS Camaro 350
71 Nissan RHD Fairlady Z
70 Stang Fastback
70 Amc AMX 390
71 240z
89 Conquest TSi w/ 5.0 v8 swap
84 Mustang GT Turbo conv
"good, if it bleeds, we can kill it ....."
Old 08-09-2003, 02:21 PM
Re: similar problem
looking for.......
any ideas ?
Dayle
That's a hard one to call.
Go to the How-to locker above, locate and do the AC diagnostic.
Mine recently stopped blowing on Auto. It was low on gas. If the temp differentials are wrong, not enough gas, the thing is programmed to shut down to save the compressor. The gas contains the oil which lubes the compressor. So not enough gas equals not enough lube equals blown compressor, ergo it shuts off.
However, I could still get the fan to run manual on 1 or 11 or 111, so your problem may be different.
Do the diagnostic, it runs through all servos, doors, motors routines, and reports a code if something is amiss.
If no code, suspect low gas.
Old 08-10-2003, 11:35 AM
svxeno
Re: Air Conditioning Problem
Too low freon pressure maybe? (Borderline perhaps) What's the name of that switch or relay?
Randy ii
Old 08-11-2003, 12:58 AM
Is it the trinary switch you mean Randy?
Old 08-11-2003, 09:10 PM
2MuchFun
Sounds like it needs some gas, cutting out on low pressure switch. If it is a R134 system that is probably the cause! Just my 2 cent
