Heat Shields
i believe that my rattle is from the heat shields
if it's the resonator after i remove the shields i'll deal what size are those bolts on the shields they seem to be 13/32nds 10mm is too small, 11mm is too big 7/16 is too big 3/8 is too small that leaves that in the middle and the ones on the manifold seem to be 15/32nds can anyone confim, i'm gonna go hit it w/ wd40.... see if i can loosen them up
SV What? |
I belive the correct size is, cut-off wheel and pry-bar. Really.
The original size was 10mm, but at this point don't expect to acctually unbolt them.
92 SVX #772 140k 6speed, ECU Tune stage II, Koni/Ground control, 3,270lbs. 91 Legacy Turbo 5spd. FMIC, crappy stock turbo, ACT clutch. 78 BRAT (New toy) (Soon to be EJ22T powered) 90 240 SX. RB25 powered!! DRIFT!!!111!!! (GF's car) To many cars to spend time on teh web! |
hmm cutoff wheel
good idea i'l have to try that another day... it's getting dark now prybar i knew they're tacked together right?
SV What? |
Thread Tools | |
Display Modes | |
