Old 06-01-2003, 09:05 PM
Brian Steel
Originally posted by mbtoloczko
I'm pretty sure that the thermostat is set to hold the water temp at a specific temperature. The thermostat speeds warm up, but after warm up, it will adjust water flow rate to keep the water at a particular temperature. That's why the needle on the water temp gauge never moves from its usual spot under normal driving conditions. If the water temp were to exceed the temperature range of the thermostat, then the water temp gauge would give varied readings depending on how hard the motor was being driven and how much air was flowing through the radiator. At any rate, I think we could get many expert opinions, but without detailed info on flow rates, radiator heat transfer effectiveness, etc, the only way we would know would be to put in a lower temp thermostat.
There is another potentially easy way to keep the motor oil cool for those who have 5 speeds. Use the ATF cooler in the radiator. You could just buy one of those adaptors that attach to the oil filter spin-on location, and voila, instant motor oil exit/entrance locations. This would also provide a means to attach a temperature sensor. Heh. I may have to do that after I put in my 5 speed. Brian, maybe you could offer this as part of your 5 speed kit?
Excellent idea, I'll have to check into that!
Old 06-02-2003, 06:44 AM
svx_commuter's Avatar
Now that you bring that up, I remember seeing a cooler/heater ring with coolant connections, between the block and filter on my Mom's Forester.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 06-02-2003, 10:44 AM
Brian Steel
Yes, several of the four cylinder Subaru engines that we have installed into Vanagons have had those coolers. I'm not sure which models came with the cooler though. Unfortunately, they cannot be used on the Vanagon conversions.
Old 06-02-2003, 11:24 AM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Be careful using the tranny cooler in the radiator! Not only is it possible that you'd be introducing whatever garbage the tranny left behind (friction material ) but the cooler, its lines and fittings are too small to accommodate the engine's oil flow requirements. Check out the difference in line sizes on, say, a late model Chevy truck, for instance.
Old 06-02-2003, 11:28 AM
Chicane Chicane is offline
Anti-BS Vigilante
I always thought the SVX ran quite hot. I mean, go for a drive, come back and pop the hood. That sucker just RADIATES heat. My big block charger never got that hot. Neither did the neon. Sometimes I have to use towel on the dipstick handle when checking the oil because the handle is so freaking hot.
- Rob
Old 06-02-2003, 02:32 PM
mbtoloczko's Avatar
sans SVX
You make good points about the cleanliness and capacity of the stock AT cooler. It should be relatively straightforward to flush the AT cooler portion of the radiator I would think. However, you are correct about the line size though. I just looked into it. [I like to get multiple opinons. :-) ]
Still, the use of an spin-on external line adaptor and an aftermarket motor oil cooler seems reasonable.
Mychailo
Visit my locker
Old 06-03-2003, 12:58 AM
Motorsport-SVX's Avatar
Motorsport-SVX Motorsport-SVX is offline
check out www.planetsvx.com
pretty sure Brian
Autometer makes a univeral kit to retro fit into
most any application. Temps out here avg much higher
then rest of the country Im sure of that...life in the
desert. Hit over 100 a month ago, and hasnt let up yet.
My mom will forever live in me and
never be forgotten, one day Ill see her again
CLICK the LINK below to Visit the SVX Store:
http://www.planetsvx.com
http://www.motorsportwarehouse.com/svx/sig2.jpg
Cars in the garage:
92 Toyota Soarer Single Turbo JDM RHD
70 Boss 302 Mustang 39k original miles
97 SVX Lsi
92 Liquid Silver Murano-ized (1st of its kind)
71 Cougar Xr7 Conv 351c 4v 4spd
69 SS Camaro 350
71 Nissan RHD Fairlady Z
70 Stang Fastback
70 Amc AMX 390
71 240z
89 Conquest TSi w/ 5.0 v8 swap
84 Mustang GT Turbo conv
"good, if it bleeds, we can kill it ....."
Old 07-11-2003, 09:43 AM
Szalkerous Szalkerous is offline
Send a message via AIM to Szalkerous
Now when using one of those spin on oil filter adapters to run an external cooler, would that add stress to the oil pump? I notice I get the heat wave every time I pop the hood after a good drive... and it concerns me almost as much as the tranny temps... I would like to grab a perma-cool oil cooler and run that system if I can.
Also, perma-cool has a bit of interesting info on engine oil cooling:
http://www.perma-cool.com/Catalog/Cat_page02.html
It's worth a read, and they sell everything you'd need.
-Sz
1994 SVX LSi - Black / Beige - 139k miles SOLD!
1999 Chevy Camaro Z28 - Black, 6-speed, hell of a ride.
2004 Chevy Silverado Z71 - Blue LT2 luxury package
Old 07-11-2003, 10:16 AM
mbtoloczko's Avatar
sans SVX
-Sz
As long as you get a engine oil cooler and not an ATF cooler, you'll be fine. The lines are larger for engine oil coolers. I'd suggest an oil temp sender and gauge. Too low of an oil temperature is also not good. Contaminants (light hydrocarbons, water vapor) don't evaporate out of the oil. If the temps are too low, then you can add an oil temperature thermostat.
Mychailo
Visit my locker
