Old 05-20-2003, 07:59 PM
elninoalex's Avatar
elninoalex elninoalex is offline
Registered Abuser
Exhaust flex joints
If you remove the flex joint in front of the center cat, is it a good idea to offer some flexibility elsewhere? I replaced my center cat with an aftermarket cat and I am getting a resonant buzz between 3000 and 3500 rpm. Could the lack of flexibility be contributing? I was thinking of using those braided stainless flex couplers in front. Any thoughts?
Stephen
92 Ebony - Level 10/n2o REAR-ENDED
92 Teal - painted yellow/4.11 5spd/n2o SOLD
92 Claret - 4.44 SOLD
94 Barcelona - FWD SOLD
92 Ebony - 3.90 SOLD
94 Laguna ROLLING w/4.44s/Ecutune ECU +TCU/STI springs/Infiniti M45 rims
Old 05-20-2003, 08:25 PM
Subafreak's Avatar
Superbeast
When I built my first exaust I didn't have any flex points in it and I didn't have any problems. However it would seam that after a wile of working it, it would fatige the metal and break somewhere. If you have an easy place to install a flex joint then you should do it althoe I don't think it has any thing to do with your noise.
Old 05-21-2003, 02:20 PM
mbtoloczko's Avatar
sans SVX
Have you tracked down the source of the noise? My guess would be that its the heat shielding around the primary exhaust pipes. Maybe just a little readjustment of the heat shielding would be necessary?
Mychailo
Visit my locker
Old 05-21-2003, 04:39 PM
elninoalex's Avatar
Registered Abuser
Actually the car contains no heat shields, other than the integral one on the new center cat. Which is probably the culprit. It has straight pipes from the manifolds back to the center cat. It really sounds great, except for that dang buzz.
Old 05-21-2003, 11:54 PM
elninoalex's Avatar
Registered Abuser
That darn cat
Actually, I should say that I do have the heat shields on the manifolds. Anyway, the new cat had a few spot welds that let go so I welded it all the way around the perimeter and now most of the noise is gone. I may end up just removing the heat shield altogether if it keeps bugging me, which it probably will.
Stephen
