interesting oil changing idea
Re: interesting oil changing idea
I've been using them on my cars for 8+ years.
http://www.fumotousa.com/ http://www.qwikvalve.com/vehicle-chart.html?id=329 I can change the Legacy and XT6 without using ramps
I'll take a drain plug and gasket any day.
You can't knock one of those loose by hitting a ground hog. Or a deer carcass.
ive changed my pearlies oil without ramps i try to find a nice little rise on the ground and parked on the top side of it lol or a small embankment/side of road washout bit on a bush trail |
I don't use jacks, ramps, anything. I just reach my long, skinny arms under and get it done. My 97 I have to lift up just a tad to get to the filter though, since it still has the undercover. The 94 hasn't had that cover thing since I got it, so it's really easy and quick.
Hmm I cant fit under my car I have to jack it up atleast 6 inches or so.....
Maybe I should cut down on the fast food
Jared 1992 dark teal SVX LS |
Ive always done the lazy "reach under and remove plug and filter by feel without jacking" method on my Subarus. I hope im able to do this with the EVO, but havent done an oil change in it yet.
I did have a Fumoto valve on the 928 without any problems, but as OT said, with a car as low as the SVX, it might be a potential recipe for disaster.
Alan 1987 928 S4 (Black) SOLD! 1997 SVX LSi (Ebony) SOLD! 2005 Legacy GT (Silver) [Cobb Stg 2+] SOLD! 1987 928 S4 (Black) SOLD! 2005 Forester XT Premium (Crystal Gray Metallic) SOLD! 2008 Lancer Evolution X MR (Apex Silver) [Cobb Stg 1+] 2015 Outlander Sport 2.4GT AWD (Mercury Gray) 2013 G37xS (Obsidian Black) |
I too have used a fumoto valve (with nipple) for years on my Legacy. But that car has a steel under-tray that makes losing it to a piece of roadkill highly unlikely, even in my lowered car. The valve makes oil changes very easy, slipping a piece of hose onto the nipple, directing the other end into my drainpan, and opening the valve. This prevents even a drop of splashing or spillage onto the floor.
The SVX is an entirely different proposition though, and I'll just keep using ramps and a ratchet thanks. Glenn
"The only thing necessary for the triumph of evil is for good men to do nothing" Aaron Burke 1993 25th Anniversary Edition #63 of 301. R.I.P. Rojo 7/24/2008 She saved my life! 1997 Ebony Mica Pearl LSI. BLACKBERRY 1998 5-Spd Legacy GT Wagon in Glacier White: NUBURU 2005 Cadillac STS in Sandstorm Metallic: STORMY Veteran and farthest traveler of 1st SoCal2MuseumsMeet2010. http://www.subaru-svx.net/photos/user.php?RojoRocket |
While using the one in my Legacy, I took it offroading in the Pine Barrens of NJ. I dug all possible bottom part of the car through sand, at one point I got stuck and had air under all 4 tires with the body sunk in the sand. Got yanked out and double checked the valve, no problem.
When driving with it on the SVX late one night, I re-hit a deer at about 70mph. It was already dead on the road, I saw it at the last minute and didn't have time to avoid it so I centered it. I felt the whole car lift as I rolled the deer under me. I never really even lifted off the gas, just checked for smoke and dash lights. The next morning I pulled it onto ramps, there was bits of hair stuck to most parts of the chassis, but the valve was fine.
Dave - 03 Baja - 92 SVX - 86 Brat - 08 OB 3.0 Last edited by Hocrest; 10-23-2011 at 08:34 AM. |
You just reminded me of the Pine Barrens episode from the Soprano's
no need for me.
I'm small enough to be able to fit underneath without jacking. |
No one would EVER drive a Subaru in an area like that!
my brother put one on his brand new forester, took it to the dealer for one of his first free oil changes and they left it open. i have had them on my cars before (they are still on the cars i just don't own them, i know because i still change their oil) without any issues. just don't let anyone else change your oil because for some reason they are too complicated for the monkeys on the lube racks.
