Old 04-20-2011, 10:02 PM
Re: NO CEL w/ key on and no spark?
Mike's problem seems to have been fixed and the car now runs!!
I'll let him fill you in on all the details. A magnificent example of tenacity.
If you cant wait, check him out on Facebook
Old 04-21-2011, 08:01 AM
Thanks to the patience and help of a number of members here in this community (Trevor, svxcess, OT, YT), I was able to isolate a problem in the fuel pump circuit. The fuel pump resistor (below the package tray) contributed/caused a short which kept blowing SBF #2 (Green 30A under the hood) and knocking out power to the ECU circuit.
Replacement of this resistor and the 30A fuse has allowed the car to run.
For future reference, the fuses ARE available at Advance Auto Parts. Each store usually stocks 2 of them. (I bought out 3 stores worth of these fuses.)
The car does stumble at idle currently so there could still be an issue with fueling. Changing the fuel pump modulator has no effects to the condition. I will suspect either a connection which has jarred loose during all of my dissassembly/diagnostics, or the fuel pump could be on its way out. (Thanks YT for the tip.)
Old 05-03-2011, 07:40 PM
Clarify stumbles at idle. rough galloping or stalls
