Old 10-09-2009, 08:56 AM
NiftySVX NiftySVX is offline
Send a message via AIM to NiftySVX
Part number needed-trans cooler lines
Does anyone know the part numbers for the hoses that run between the two steel lines for the trans cooler, right behind the LH head? My parts catalog doesn't show them.
2007 GS 450h-Active Stabilizer/Radar cruise
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Toyota Master Diagnostic Technician (former life)
Old 10-09-2009, 09:18 AM
StelthSvx's Avatar
StelthSvx StelthSvx is offline
Re: Part number needed-trans cooler lines
i relpaced those with standard oil hose, just cut to length. They dont have much molding in them, thus standard hose will work fine....
92' Claret LSL 282,000 miles 1owner(ME)
07' Pearly WRX 40k Cobb Stage II (sold)
SVX+$$$+GreaseMonkey =
Old 10-09-2009, 09:25 AM
45521PA031...Hose ATF Inlet...$27.50...(number 5 on the diagram)
45521PA041...Hose ATF Outlet...$48.41...(number 6 on the diagram)
It is located on the Subaruparts website. It is in the Engine Cooling [2] section of the 1992 SVX.
http://www.subaruparts.com/diag/?mod...category=450-B
Old 10-09-2009, 07:50 PM
StelthSvx's Avatar
thought he was refering to #7 in diagram( "hoses behind LH head")>.......
Old 10-09-2009, 08:44 PM
Originally Posted by StelthSvx View Post
thought he was refering to #7 in diagram ("hoses behind LH head")
In that case, you would need 2 hoses, P/N 45521PA051... $13.42 each. (number 7 on the diagram)
These hoses attach directly to the transmission on the driver's side.
Old 10-09-2009, 11:19 PM
Green1995SVX's Avatar
I just used regular hose on mine. I had to make a loop in the hose to keep it from kinking because of the angle.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
