Old 08-02-2006, 12:35 AM
SubaRyu's Avatar
SubaRyu SubaRyu is offline
Domo Arigato
I polished headlights.
Here are the photos.
I started with #400 wet sanding, end up #2000 and used couple types of polishing chemicals to shine the surface.. result is OK, not 100% happy with it, but definitely got better than before! No yellow so far. Strange thing is, when I put headlights back to the car, they didn't look clear as I saw in my room. Losing the shine minute by minute??
I think I still have to polish from inside.
Yes my wheels are still backwards..
-Ryu
Links:
2004 Honda S2000 (2008~)
1992 Subaru SVX LSL Liquid Silver (2007~2008)
1996 SVX LSi Bordeaux Pearl (2006~)
2002 Lexus IS300 Sportcross (2005~)
1992 Subaru SVX LSL Pearl White (2001~2005)
1994 Mercury Sable GS (1999~2001)
1/43 Scale SVX Models
[SIGPIC][/SIGPIC]
Old 08-02-2006, 01:19 AM
SVX PlayBoy SVX PlayBoy is offline
Send a message via AIM to SVX PlayBoy
Those look really good actaully. Mine are pretty bad, want to do them soon. Could you post or PM what you did, and the products you used. sort of like a write up,
thanx
Dean
Old 08-02-2006, 03:21 AM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
They do look better than before.
Maybe if you do it few more times, it will become even better.
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 08-02-2006, 04:56 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
Beautiful car though....nice job
1995 Subaru Svx L / AWD
Old 08-02-2006, 05:09 AM
zavikan zavikan is offline
Send a message via AIM to zavikan
Soap
I found that by simply removing them and washing them out with soap (without disassembly) made mine clearer. Gunk build up on the inside. Mine came off a car that sat for 3 years though outside.
Meh, just offering tidbits of what I've experienced
'92 Liquid Silver SVX - Drilled&Slotted Rotors/Canadian OEM Seat Warmers/JDM Folding Mirrors/JDM Clear Corners/Euro Glass Headlights/Euro Headlight Level Adjustment/Euro Shifter Assembly/ECUTune Chip V.1/GARAGE QUEEN!
Old 08-02-2006, 11:14 AM
triumph1902's Avatar
triumph1902 triumph1902 is offline
400 grid is way too coarse for plastic. You should have stayed with 1500 and 2000...would have taken longer but come out better. Also what did you polish them with. You need to use an orbital buffer with compound used to polish clear coat finishes...that's how you get the true shine.
________________________
92 Teal - Work in progress
Old 08-02-2006, 08:57 PM
SubaRyu's Avatar
Domo Arigato
thanx
Dean
Mine were pretty yellowish. I thought it was plastic itself but found out it was just surface. So basically sanding and polishing took good care. I started from #400 wet since the lense surface was scratched up. 500, 600, 800, 1000, 1500, 2000 (all wet sanding) and polishing compounds.When you sanding you can actually see yellow stuff coming off from surface. If you be careful not leaving deep scratchs at every step, it will just look like matt finish surface. Then I used Meguiars products. The polish for clear plastic lense wasn't working well, so I used show car glaze 7. I know that's actually for body surface, but I knew it would work for plastic as well. Then there comes clear and shine instantly. It worked great for mine. Result might vary depends on how you do all the steps.. Polishing actually takes a lot of energy. Mine look pretty clear still. Just inside surface need to be polished as well to be perfect, but for now it's OK....
BTW, you probably don't need to remove headlights but it was pretty hot day and I didn't wanna stay outside....
-Ryu
Links:
[SIGPIC][/SIGPIC]
Old 08-02-2006, 08:59 PM
SubaRyu's Avatar
Domo Arigato
Yeah, more is better. I think the outside surface is good. Just inside...
-Ryu
Links:
[SIGPIC][/SIGPIC]
