Checking Trans Fluid level
Is there a decent way to check the fluid level in the transmission? My first thought was that it had been low for a long time so I put a quart of the most expensive stuff I could find from AutoZone (Valvoline MaxLife) and I noticed that the 2-3 shift is a lot better (much less lag and crisper). But anyway it doesn't matter whether the car is warm or cold; whenever I put the dipstick in and bring it back up there are "dry spots" below the low marks, but trans fluid still goes up to about four inches above the end of the stick. How can I get an accurate reading?
To get the most accurate reading you have to wait quite a while after adding any fluid. When you slide the dipstick back in it rubs the side of the tube which is coated with the fluid you just poured in.That is why you see it 4 inches up the stick.
Another thing you can do is rough up the end of the dipstick with some sandpaper, this will help the fluid stick to it instead of running off of the smooth finish
Mike 92 LSL Teal 103k 00 RS 2.5 Silverthorn Metallic 36k 68 Chevy Camaro 07 Forester XT Sport |
