Old 01-26-2006, 11:42 AM
Lights dim and brighten, dim and brighten...
Ok, I have been ignoring this problem for a while, but now that I have the other problems fixed, I can focus on this one. The interior lights, and headlights are diming and brightning. It is more pronounced when the car is cold. What should I have checked? I am guessing Battery or Alternator. Anything else I should have looked at?
Old 01-26-2006, 02:35 PM
Earthworm's Avatar
Meow!
If anything the alternator. At what RPM's do you notice this?
The lights will probably dim at any RPM at or below idle.
Old 01-26-2006, 05:01 PM
The alternator upgrade may be the answer. (found in the How-To Docs)
Old 01-26-2006, 07:43 PM
crimsonnblue
I too have a similar problem except it only does it once in the morning when im pulling out of my parking spot...
Old 01-27-2006, 07:11 AM
This can be such a fun car....
Probably time to get it checked out professionally. Today on the way into work the radio died, then a minute later the car stalled and died. Turning the key would not crank the engine. I called AAA Roadside and while on the phone with them I kept trying to start the car. After about 5 minutes it started right up, and I was able to get to work.
Oh and the lights are dimming and brightning at all RPM's although it seemed slightly worse at idle than at highway speed.
I swear I'll get this car straightened out sooner or later, however I may go broke in the process. I'll probably need to change my signature to "Car F*cked Up Again"
Old 01-31-2006, 05:59 PM
Alternator was the problem.
I just got it back, the shop said that the alternator had "significant internal problems". Anyhow my pockets are a little lighter, but no more flashing headlights.
