Old 11-24-2005, 10:27 AM
PaulSVX's Avatar
PaulSVX PaulSVX is offline
Tranny...again
My tranny is acting a little strange. it has a hard shift from 1st to 2nd when cold, when it is warm everything is good. I checked fluid level, resistor everything seems to be good. any input will be appreciated. I'm suspectiong one of the solenoids.
Thanks
1992 Pearl White SVX LS-L
1991 "Red Baron" Grand Prix GTP 5spd
2002 Chevy TrailBlazer LT
Old 11-25-2005, 10:30 AM
Earthworm's Avatar
Meow!
Double check the resistance of the resistor behind the battery. Could also be a loose connection to that resistor.
Old 11-25-2005, 09:01 PM
oab_au oab_au is offline
Could be a few things
Like a dud temp sensor in the trans, not cutting the line pressure back till it is warm. A sticking A solenoid. Not having the water cooler, the last one when fitting an aditional cooler. Wrong time of the month.
Try letting it run for 15 minuits, to get the oil very warm, see if in does it then.
One Arm Bloke.
Tell it like it is!
